Ok so tell me what i can do to resolve, all nodes have the default settings.
that being said there are more than 30 nodes behind this router at this time with more to come.
are you then saying that allstar can not support this?
i am not being given much information on what to look for?
if something is broken i need more information to find it.
is this one node, a few nodes, all notes or the combination of all nodes.
or are you saying that allstar can not support support the large number of nodes? if so what is the limit?
to ban someone without giving enough information to resolve the issue and without notice ( things where working good for a little while) is outrageous.
to be clear the general statement
“You really have to be flooding the hell out if stats like
he is to trigger this rule and ban action”
is overly general, does not provide any information on which node is causing this, or exactly what can cause this.
i am use stock settings with respect to any reporting, i changed nothing thus i do not know where to look.
or is this due to the number of nodes behind the firewall?
Please more info
On Saturday, May 16, 2020, 12:44:20 PM PDT, Tim Sawyer via AllStarLink Discussion Groups noreply@community.allstarlink.org wrote:
wd6awp
ASL Admin
May 16
Our sysadmin says you are hitting firewall rate limits:
To keep people from flooding it and killing uhandler and apache there
is a limit of 20 new connections to 80/443 in 1 second and a max of
50 over 7 seconds. He is consistently hitting this limit due to his
flooding of stats from one or more private nodes
After hitting these firewall rules 100 times in an hour fail2ban will ban
you for 2 hours. You really have to be flooding the hell out if stats like
May 16
there may be a difference in methodology here, I am using a software called ping plotter and i am showing no ping response from the address ending in 254 however if i change to a different ip address it works. this is using the exact same equipment, computers, routers allstar nodes. Furthermore us…
May 16
there may be a difference in methodology here, I am using a software called ping plotter and i am showing no ping response from the address ending in 254 however if i change to a different ip address it works. this is using the exact same equipment, computers, routers allstar nodes. Furthermore using the same equipment and changing the ip address on the router from 254 to a different ip address on the same internet circuit causes everything to work.
also pinging anything other than stats.allstarlink.org works as expected, such as 8.8.8.8, google.con, twitter.com all ping.
furthermore inbound connections to the HTTP server on port 80 of the 254 ip address (port forwarded in the router) work as expected
and inbound allstar connections for other nodes (not mine ) using the public internet connect as expected.
the only think that does not work is the http://stats.allstarlink.org/
thus as inbound connections to port 80 and to the allstarlink nodes work, outbound to everywhere else works (i am sending this email thru the same network using the .245 address, the same equipment on a different ip address solves the problem, the only thing left is that allstarlink has blacklisted and or blocked my ip address for reasons unknown, just like bryan has done in the past. and this has absolutely nothing to do with using .254 as this worked for years before bryan messed with blacklisting me.
this all started 8-12-2018 when bryan black listed 254 and has been intermittent ever since, before that it worked fine.
how do i get this resolved?
wd6awp
ASL Admin
May 16
My traceroute ends at 104.128.206.50 also, but I can ping stats.allstarlink.org even so.
traceroute stats.allstarlink.org
traceroute to stats.allstarlink.org (44.103.34.83), 30 hops max, 60 byte packets
1 internal.e4.router.la.nfoservers.com (104.153.109.254) 0.332 ms 0.324 ms 324.267 ms
2 las-b24-link.telia.net (62.115.190.80) 0.645 ms 0.634 ms 0.606 ms
3 rest-bb1-link.telia.net (62.115.114.87) 56.313 ms 55.795 ms ash-bb2-link.telia.net (62.115.121.221) 55.785 ms
4 ash-b1-link.telia.net (62.115.143.121) 55.744 ms ash-b1-link.telia.net (80.91.248.157) 55.364 ms 55.884 ms
5 chartercommunications-svc064253-ic345845.c.telia.net (62.115.177.175) 56.496 ms 56.477 ms 56.471 ms
6 bbr01ashbva-bue-3.ashb.va.charter.com (96.34.3.50) 72.803 ms 71.238 ms 73.692 ms
7 bbr01sgnwmi-bue-4.sgnw.mi.charter.com (96.34.0.243) 70.819 ms 68.270 ms 68.245 ms
8 crr01sgnwmi-bue-1.sgnw.mi.charter.com (96.34.2.57) 67.924 ms 67.910 ms 67.358 ms
9 crr01aldlmi-bue-5.aldl.mi.charter.com (96.34.34.242) 68.217 ms 68.206 ms 68.195 ms
10 crr02aldlmi-bue-21.aldl.mi.charter.com (96.34.32.35) 69.113 ms 68.480 ms 68.466 ms
11 dtr02mdvlmi-bue-19.mdvl.mi.charter.com (96.34.40.31) 67.846 ms 67.835 ms 67.732 ms
12 150.181.5.183 (150.181.5.183) 67.212 ms 67.575 ms 67.563 ms
13 096-036-053-022.biz.spectrum.com (96.36.53.22) 67.905 ms 67.619 ms 67.863 ms
14 104.128.206.50 (104.128.206.50) 67.286 ms 67.603 ms 67.367 ms
15 * * *
16 * * *
17 * * *
18 * * *
19 * * *
20 * * *
21 * * *
22 * * *
23 * * *
24 * * *
25 * * *
26 * * *
27 * * *
28 * * *
29 * * *
30 * * *
root@rambo3:~# ping stats.allstarlink.org
PING stats-grr.allstarlink.org (44.103.34.83) 56(84) bytes of data.
64 bytes from 44.103.34.83 (44.103.34.83): icmp_seq=1 ttl=52 time=67.9 ms
64 bytes from 44.103.34.83 (44.103.34.83): icmp_seq=2 ttl=52 time=68.0 ms
64 bytes from 44.103.34.83 (44.103.34.83): icmp_seq=3 ttl=52 time=67.8 ms
64 bytes from 44.103.34.83 (44.103.34.83): icmp_seq=4 ttl=52 time=67.9 ms
64 bytes from 44.103.34.83 (44.103.34.83): icmp_seq=5 ttl=52 time=67.7 ms
64 bytes from 44.103.34.83 (44.103.34.83): icmp_seq=6 ttl=52 time=67.8 ms
64 bytes from 44.103.34.83 (44.103.34.83): icmp_seq=7 ttl=52 time=67.7 ms
64 bytes from 44.103.34.83 (44.103.34.83): icmp_seq=8 ttl=52 time=68.0 ms
64 bytes from 44.103.34.83 (44.103.34.83): icmp_seq=9 ttl=52 time=67.9 ms
64 bytes from 44.103.34.83 (44.103.34.83): icmp_seq=10 ttl=52 time=67.6 ms
^C
--- stats-grr.allstarlink.org ping statistics ---
10 packets transmitted, 10 received, 0% packet loss, time 9012ms
rtt min/avg/max/mdev = 67.671/67.877/68.043/0.355 ms
May 16
Hi
also please note the trace route plots i sent, the plot ending in 254 goes all the way to the router 104.128.206.50 this appears to be the last router before just before stats.allstarlink.org , thus my ip address is working and this indicates that http://stats.allstarlink.org/ is not responding to my ip address ending in 254.
chris
the service is a fiber delivered business class service in our server room 254 is a valid address on this service, no routers there.
it does not piing when i use it.
this has been the ip address for some time, never had issues before bryan messed with it.
wd6awp
ASL Admin
May 16
chris43:
also a computer on the same public address via the router can not ping stats.allstarlink.org
I’ll ask our sysadmins to check if you are blocked. But a last octet of 254 is sometimes used for a router. Do you think that could be the problem? Can you ping 254 when you are not using it?
May 16
interesting, was that me or someone else?
May 16
wd6awp
ASL Admin
May 16
chris43:
