Nodes not showing up on the status page
thank you for giving me direction on where to look, as i do not know how the servers communicated with the allstar servers i did not know to look there. i never ran into this before.
i believe i have logged into every node and corrected this where i found it wrong.
i am unsure how this would have changed as i never had more than one node on each Pi server.
hopefully this resolves this issue
it is very helpful when the knowledge is shared
On Saturday, May 16, 2020, 08:17:29 PM PDT, Nate Hardman via AllStarLink Discussion Groups noreply@community.allstarlink.org wrote:
Nate_Hardman
ASL Admin
    May 17
I’m sure it’s not the register statement in iax.conf. It would be the statspost line in rpt.conf in the private nodes stanza that is the issue. I’d say make sure you are not attempting to report stats for private nodes to the asl servers. If only valid node numbers were reporting stats from an IP address then I’m sure ASL would not have any problem making an exception. But I’m pretty sure they have every right to block an IP that is sending junk attempts.
Thank you
Nathan Hardman
Nhardman1428@gmail.com
chris43
    May 16
why do i need to keep prodding for more information, allstalink should clearly and consistency giving all information when telling someone that they have a problem. if you know it is a private node, tell the offender what privet node is causing the issue and how to fix it, why is this asking for t…
chris43
    May 17
All 3 private nodes are now public nodes
this should resolve the issues as there are no private nodes
please remove the .254 from blacklist
if you see anything else please tell me exactly what you are seeing
chris43
    May 17
Why is the allstarlink staff so opposed to actually giving what they are actually seeing as the issue???
first the answer was that my ip address ended in .254 now the guess is node 1999
what about the actual data instead of guessing???
if someone would give me exact ally what they are seeing as the issue, such node number mac address something useful instead of general statement this could have resolved long ago.
in the ham VoIP by default the 1999 is commented out.
i provided the iax.conf registration lines showing both the private node number i assigned and the 1999 being commented out.
so it seems now i see hwy i am being singled out here, and not being helped it is because i am using the hamviop version.
some of the reasons i use the hamvoip version are when i was having issues with DIAL, the allstaling staff was not helpful (much like today) and the Hamvoip team was helpfull and without the bad attitude i and lack of information was getting from the allstarlink team.
now fast forward to today, last week i wanted to try a more powerful server to see if would resolve what i was doing. This was not an easy task, the asterisk service did not start and as a module was missing, had to research and find a solution, this took some time.
now if i need to build a hamvoip server if the radio is ready with the cable including burning the sim, i can have it working in 20 to 25 minuets. Huge difference.
now i will likely be told about the open source issues, frankly i do not care about those issues, the hamvoip team is easy to work with, and the software works, thus i do not care about the open source issues.
all i care about does it work and it does can i get answers what i kneed knowledge, yes i can. Unlike the allstarlink team.
tell me the exact node numbers mac address (something i can work with) you are having issues with and i will correct it
David_McGough
    May 16
On HamVoIP, by default, the registration and stat posts for node 1998 and 1999 are commented out and only present as an example of how to configure for public nodes.
wd6awp
ASL Admin
    May 16
What about all the number 1999 nodes that exist on every HamVoIP node by default? Are those all not registering or stat posting?
chris43
    May 16
if you know it is a private node, tell the offender what privet node is causing the issue and how to fix it, why is this asking for too much.
i have a total of 3 private nodes here is from the iax.conf of each node
;register => 1128:@register.allstarlink.org
;register => xxxxx:yyyyyy@register.allstarlink.org
;register => 1129:@register.allstarlink.org
;register => 1127:@register.allstarlink.org
as you can see the line to not register is commented out.
if there is a private node left on by error more information will help to find it.
the WAN spans 2 States.
furthermore i find it hard to believe that even if my 3 nodes are where registering inappropriately that it could cause so much trouble that i need to be banned.
if errant data from 3 nodes can bring down the system i am surprised it works at all.
furthermore it seems to that allstarlink’s unwillingness to provide information and assistance tells mat they do not care to help, point fingers as this-is all i seem to get from allstarlink.
with by=ryans departure i thought allstarlink would improve i guess i was wrong.
instead of asking me to prove a negative (that i am not doing something) tell me what i need to know to resolve this issue.
as i keep asking please provide more information
