Help setting up USB Sound with vox
Hi I’m new and got stuck setting up the node
Hardware :
-Rapberry Pi 4
  • Cheap USB Sound Card
  • Baofeng UV5
  • Easy Digi KF5INZ
I guess my node is set up , I can see the green on the nodes list.
Problem , I do not need the cos or ptt thing or modify a usb sound , is it possible just to configure the vox to handle the PTT .
I know all the pros and cons about using the VOX, but for now that’s all what I need
when running simpleusb-tune-menu :
Active simpleusb device stanza : [USB]
but then I get a message " Device usb currently not active"
Thanks For the help
Cesar,
I am not sure what you mean by “cheap usb sound card”
You need a USB audio sound fob with a specific chip that is supported by app_rpt.
It needs to be one of the following CM108, CM119 or CM119B ’
Look for USB sound fobs with one of these chips.
Marshall - ke6pcv
From: Cesar Gonzalo via AllStarLink Discussion Groups [mailto:noreply@community.allstarlink.org]
Sent: Monday, January 27, 2020 10:27 AM
To: ke6pcv@cal-net.org
Subject: [AllStarLink Discussion Groups] Help setting up USB Sound with vox
Cesar_Gonzalo
January 27
Hardware :
-Rapberry Pi 4
· Cheap USB Sound Card
· Baofeng UV5
· Easy Digi KF5INZ
Thanks For the help
I bought it cause I saw this diagram.
Thought any cheap usb sound card will do it.
Thanks.
I’ll look for one with that specs.
On Mon, Jan 27, 2020, 16:53 Marshall Oldham via AllStarLink Discussion Groups noreply@community.allstarlink.org wrote:
KE6PCV
      ASL Admin
    January 27
Cesar,
Marshall - ke6pcv
··· (click for more details)
In Reply To
Cesar_Gonzalo
    January 27
Hi I’m new and got stuck setting up the node Hardware : -Rapberry Pi 4 Cheap USB Sound Card
Baofeng UV5
Easy Digi KF5INZ
I guess my node is set up , I can see the green on the nodes list. Problem , I do not need the cos or ptt thing or modify a usb sound , is it possible just to configure …
Cesar,
The particular setup appears to use the GPIO pin 12 on the Pi board for PTT, I don’t think app_rpt software supports using the Pi GPIO pins for PTT.
Generally from what I understand, the app_rpt software uses a GPIO pin on the USB sound fob.
The diagram you provided appears to be for some other software platform which supports using the Pi GPIO pin for PTT such as the Svxlink or OpenRepeater project.
Check out the following USB sound fobs that will work.
http://www.masterscommunications.com/products/radio-adapter/ra25.html
https://dmkeng.com/URI_Order_Page.htm
Or buy a really cheap sound fob from here.
https://www.ebay.com/itm/Free-driver-USB-Sound-Card-CM108-USB-Sound-Card-Chip-Blue-J3J1/113783638459?hash=item1a7e0889bb:g:pOAAAOSwfx9dA~oc
Then modify it yourself.
http://www.garydion.com/projects/usb_fob/
Marshall
Sent: Monday, January 27, 2020 2:12 PM
Cesar_Gonzalo
January 27
Thanks.
In Reply To
KE6PCV ASL Admin
January 27
Cesar, I am not sure what you mean by “cheap usb sound card” You need a USB audio sound fob with a specific chip that is supported by app_rpt. It needs to be one of the following CM108, CM119 or CM119B ’ Look for USB sound fobs with one of these chips. 73 Marshall - ke6pcv ··· (click for more details)
Previous Replies
KE6PCV ASL Admin
January 27
Cesar,
Marshall - ke6pcv
Cesar_Gonzalo
January 27
Hardware :
-Rapberry Pi 4
· Baofeng UV5
· Easy Digi KF5INZ
Thanks For the help
I bought this one …
I hope that ine works .
Do I need to modify this card to use it with Vox?
Is that posible, or I do need to set up the ptt cos
Thanks for the help
On Mon, Jan 27, 2020, 18:06 Marshall Oldham via AllStarLink Discussion Groups noreply@community.allstarlink.org wrote:
KE6PCV
      ASL Admin
    January 27
Cesar,
Marshall
In Reply To
Cesar_Gonzalo
    January 27
I bought it cause I saw this diagram. Thought any cheap usb sound card will do it. Thanks. I’ll look for one with that specs. [wiring-diagram-baofent.jpg]
See this about GPIO https://wiki.allstarlink.org/wiki/Manipulating_GPIO
Ok hope some one can help me…
Now I got the sound FOB , seems to be working fine.
With the easy digi vox by kf5inz
I guess node is up
If I type RPT FUN 51024 *81
I’m getting the time on my other radio , so the vox part is working and is ptt’in the radio.
My problem now is that when I use the other radio seems like the audio in its not going trough.
I hooked an speaker to check if the *81 send from the radio is going trough the easy digi and it does , but i have no response fron the computer back
Any Idea
Thanks for your help
On Mon, Jan 27, 2020, 23:31 Tim Sawyer via AllStarLink Discussion Groups noreply@community.allstarlink.org wrote:
wd6awp
      ASL Admin
    January 28
In Reply To
KE6PCV
      ASL Admin
    January 27
Cesar, The particular setup appears to use the GPIO pin 12 on the Pi board for PTT, I don’t think app_rpt software supports using the Pi GPIO pins for PTT. Generally from what I understand, the app_rpt software uses a GPIO pin on the USB sound fob. The diagram you provided appears to be for some …
