I bought it cause I saw this diagram.
Thought any cheap usb sound card will do it.
Thanks.
I’ll look for one with that specs.
On Mon, Jan 27, 2020, 16:53 Marshall Oldham via AllStarLink Discussion Groups noreply@community.allstarlink.org wrote:
ASL Admin January 27Cesar,
I am not sure what you mean by “cheap usb sound card”
You need a USB audio sound fob with a specific chip that is supported by app_rpt.
It needs to be one of the following CM108, CM119 or CM119B ’
Look for USB sound fobs with one of these chips.
January 27Hi I’m new and got stuck setting up the node Hardware : -Rapberry Pi 4 Cheap USB Sound Card
Baofeng UV5
Easy Digi KF5INZ
I guess my node is set up , I can see the green on the nodes list. Problem , I do not need the cos or ptt thing or modify a usb sound , is it possible just to configure …
