I do not think you have a choice with the RIM-Alinco, the unit comes pre-wired to discriminator audio pin only.
Looking at the site, here are the suggested settings using the RIM-Alinco and SimpleUSB.
From: Tim Sawyer via AllStarLink Discussion Groups [mailto:noreply@community.allstarlink.org]
Sent: Saturday, March 21, 2020 12:34 PM
To: ke6pcv@cal-net.org
Subject: [AllStarLink Discussion Groups] [App_rpt-users] Troubleshooting Help
wd6awp ASL Admin
March 21
That’s sounds like you have the receive audio connected to discriminator audio out of the Alinco. Is there another pin that has squelched audio? If so try that as it would be your best option. If there is no other pin you can use for audio output, try using simple-tune-menu to set de-emphasis to on. That may correct the audio characteristics to help the DTMF issue. Also it will probably make your audio sound less tinny to connected nodes.
Another thing that will often help DTMF decoding is to turn on the CTCSS Rx filter.
Previous Replies
KE6PCV ASL Admin
March 21
You probably need to turn off the full duplex setting in rpt.conf and make it a simplex.
Edit your rpt.conf and change
duplex=3
to
duplex =1
reboot the node and see if that helps.
The duplex key/value pairs sets the duplex mode for desired radio operation. Duplex mode 2 is the default if none specified.
Duplex Mode
Description
0
Half duplex with no telemetry tones or hang time. Special Case: Full duplex if linktolink is set to yes. This mode is preferred when interfacing with an external multiport repeater controller. Comment out idrecording and idtalkover to suppress IDs.
1
Half duplex with telemetry tones and hang time. Does not repeat audio. This mode is preferred when interfacing a simplex node.
2
Full Duplex with telemetry tones and hang time. This mode is preferred when interfacing a repeater.
3
Full Duplex with telemetry tones and hang time, but no repeated audio. See details
4
Full Duplex with telemetry tones and hang time. Repeated audio only when the autopatch is down.
Sample:
duplex = 0 ; 0 = Half duplex with no telemetry tones or hang time.
Marshall - ke6pcv
··· (click for more details)
KF8IV
March 21
I gave them a call and left message.
Fingers crossed!
Ryan
KE6PCV ASL Admin
March 21
Ryan,
Sounds like a simple configuration settings issue.
I would follow the directions provided by the folks that you bought the RIM-Alinco from.
If they did not provide directions I would contact them directly.
I am sure that they have a basic configuration setting instructions for their RIM-Alinco to get you up and running easily.
Marshall - ke6pcv
KF8IV
March 21
Hello,
Yes, sorry. The ASCII graph disappears when I PTT.
I hear audio coming from the radios speaker when I key it.
I do not have it set to duplex. Its set to partial simplex I think it was #1.
N3xcc
March 21
When I key my HT, the graph disappears, sound comes through the radio and then when I release the PTT the graph reappears
again.
I’m not sure I understand this. When you key your radio, and you have the volume on the DR-135 turned up, do you hear normal
audio coming from the radio’s speaker? If you get garbled audio from the 135’s speaker, something is wrong with the 135 or
your HT.
I’m not sure what you mean by the “graph disappears.” do you mean the video disappears, or that the indication on the bar
graph disappears?
Could you have the node programmed for full-duplex in the AllStar config files and thus the DR-135 is going into transmit
mode in response to an incoming signal?
Scott
Scott Zimmerman
Amateur Radio Call N3XCC
474 Barnett Road
Boswell, PA 15531
