When I key my HT, the graph disappears, sound comes through the radio and then when I release the PTT the graph reappears
again.
I’m not sure I understand this. When you key your radio, and you have the volume on the DR-135 turned up, do you hear normal
audio coming from the radio’s speaker? If you get garbled audio from the 135’s speaker, something is wrong with the 135 or
your HT.
I’m not sure what you mean by the “graph disappears.” do you mean the video disappears, or that the indication on the bar
graph disappears?
Could you have the node programmed for full-duplex in the AllStar config files and thus the DR-135 is going into transmit
mode in response to an incoming signal?
Scott
Scott Zimmerman
Amateur Radio Call N3XCC
474 Barnett Road
Boswell, PA 15531
On 3/21/2020 1:23 PM, Ryan Hartnett via AllStarLink Discussion Groups wrote:
[KF8IV] KF8IV https://community.allstarlink.org/u/kf8iv
March 21Hello,
I am new to Allstar so please be gentle.
I have setup my Allstar node with a raspberry pi 3, Alinco D135 and the RIM-Alinco interface. The node is recognized online
through Allstarlink. I have Echolink up and running without a problem.The issue is this: my DTMF codes dont work when I key the radio with my HT. When I have someone connect to my node, he says
its all static. When I run the simpleusb-tune menu, I go to the visual graph with rx. When I key my HT, the graph disappears,
sound comes through the radio and then when I release the PTT the graph reappears again.Any help would be appreciated. I think I have this about 99% setup correctly?
Thanks!
Ryan, KF8IV
Visit Topic https://community.allstarlink.org/t/troubleshooting-help/16688/1 or reply to this email to respond.
To unsubscribe from these emails, click here
https://community.allstarlink.org/email/unsubscribe/9f9e31d6212dd5d46cd381cffab2e2bd7101b013d7685e81ab95a38ab1973f18.
