Nodes connected to each other WITHOUT allstar "server'?
The way I understand it …
when any node connects to another it is “through” an allstar server.
As I\m not 100% sure about this, can someone please explain.
Is ALL the traffic handled by a server, or does the server just
tell the nodes how to find each other (DNS) ?
IF all the traffic goes through the server ( another Asterisk in the “sky”),
how can I connect two nodes to each other without an Allstar server.
ie, “order wire” for (interoffice communication) .
Direct IP to IP address ??
Thanks
Don, K8ZGW
Don,
Connecting two nodes together on a private network is actually pretty easy.
What you will need to do is add the node and IP address of the other node(s) to each servers rpt.conf in the [nodes] stanza.
Here’s an example with two nodes on a private network.
Server A’ s IP is 192.168.1.10 and B is 192.168.1.11.
SERVER A rpt.conf
[nodes]
1000 = [email protected]/1000,NONE ; Local node
1001 = [email protected]/1001,NONE ; Remote node
SERVER B rpt.conf
[nodes]
1001 = [email protected]/1001,NONE ; Local node
1000 = [email protected]/1000,NONE ; Remote node
Of course you need to have all the normal stuff that nodes have in rpt.conf and extensions.conf.
Private nodes do not need a register line in iax.conf.
From: Don Ritchie via AllStarLink Discussion Groups [mailto:[email protected]]
Sent: Wednesday, November 20, 2019 10:49 AM
To: [email protected]
Subject: [AllStarLink Discussion Groups] Nodes connected to each other WITHOUT allstar "server’?
k8zgw
November 20
Thanks
Don, K8ZGW
You can connect the two nodes together via GRE tunnel or OpenVPN (with compression off, and crypto set low or off) and/or use 44net addresses for the tunnel or VPN connection. Then using iptables, you can allow traffic over the VPN link and block it from the outside world.
Can this be done with a pair of RTCM’s? Could I have just that hardware with no other “computer” involved. Just plug into a router at one location and another and use the internet?[quote=“Marshall_Oldham, post:2, topic:15728, full:true”]
Don,
SERVER A rpt.conf
[nodes]
SERVER B rpt.conf
[nodes]
k8zgw
November 20
Thanks
Don, K8ZGW
[/quote]
have you got it working yet. i may be able to help. I have seen the code and maybe able to copy it
You are going to need one computer to connect 2 RTCMs.
On 12/27/19 5:55 PM, WQXN966 Jason via
AllStarLink Discussion Groups wrote:
WQXN966_Jason
WQXN966_Jason
              December 27
able to copy it
K4SAT
K4SAT
              December 27
post:2, topic:15728, full:true”] Don, Connecting two nodes
together on a private network is a…
Visit
Topic
mode.
You need a Pi loaded with the software and a open port to it as well
It takes two things for the RTCM to work,
  1. RTCM needs a network connection.
  2. You will need a server(computer) or Pi connected to the same network somewhere else with ASL running so that the RTCMs can call home to make the connections to each other.
No computer needed at the physical location of the RTCMs. Only network connection back to the Pi or Server (computer).
I hope this answers your question.
From: K4SAT via AllStarLink Discussion Groups [mailto:[email protected]]
Sent: Friday, December 27, 2019 1:57 PM
K4SAT
December 27
Don,
SERVER A rpt.conf
[nodes]
SERVER B rpt.conf
[nodes]
··· (click for more details) [/quote]
Marshall_Oldham ASL Admin
November 20
Don, Connecting two nodes together on a private network is actually pretty easy. What you will need to do is add the node and IP address of the other node(s) to each servers rpt.conf in the [nodes] stanza. Here’s an example with two nodes on a private network. Server A’ s IP is 192.168.1.10 and …
ke4ahr
November 21
November 20
Don,
SERVER A rpt.conf
[nodes]
SERVER B rpt.conf
[nodes]
k8zgw
November 20
Thanks
Don, K8ZGW
So to be clear, correct me if I am wrong, two (or more) RTCM’s connected via Internet to ASL (or other) server without a local computer. Two RTCM’s on a private network via internet require a “Pi server” at one end?
(Note edited 4pm EDT)
One or more RTCMs require a single server. That server can be a RPi
or any other computer capable of running ASL. All RTCMs must be able
to contact the server via a network.
N4IRS
On 12/28/19 3:57 PM, K4SAT via
K4SAT
K4SAT
              December 28
me if I am wrong, two (or more) RTCM’s connected via ASL
a private network require a “Pi server” at one end?
Marshall_Oldham:
work,
  1.                 RTCM needs a
network connection.
  1.                 You will need a
··· (click for more
details)
Marshall_Oldham
Marshall_Oldham
ASL Admin
              December 28
to work, RTCM needs a network connection. You will need a
home to make the connections to each other. No computer
needed at the physical location …
Visit
Topic
mode.
Think of a RTCM as a IP connected radio interface (vs USB connected
radio interface)
K4SAT
K4SAT
              December 28
Marshall_Oldham:
work,
  1.                 RTCM needs a
network connection.
  1.                 You will need a
··· (click for more
details)
Marshall_Oldham
Marshall_Oldham
ASL Admin
              December 28
Visit
Topic
mode.
OK;
So
  1. I have an RTCM at my home, along with a Pi running ASL. A second RTCM is installed at a repeater 8 miles away connected to a local LAN via internet, or a cellular modem. That will work?
  2. I have two RTCM at those locations, both point to ASL’s severs with no other computer required. That will also work?
Yes two or more RTCM's connected via ASL whether it is a private network or over the internet require a computer or pi running ASL and configured for the RTCMs.
The server can be anywhere on the private network or internet.
Sent: Saturday, December 28, 2019 12:57 PM
Subject: [AllStarLink Discussion Groups] Nodes connected to each other WITHOUT allstar "server'?
K4SAT
December 28
So to be clear, correct me if I am wrong, two (or more) RTCM’s connected via ASL (or other) server without a local computer. Two RTCM’s on a private network require a “Pi server” at one end?
Marshall_Oldham:
  1.  You will need a server(computer) or Pi connected to the same network somewhere else with ASL running so that the RTCMs can call home to make the connections to each other.
December 28
It takes two things for the RTCM to work, RTCM needs a network connection. You will need a server(computer) or Pi connected to the same network somewhere else with ASL running so that the RTCMs can call home to make the connections to each other. No computer needed at the physical location …
December 28
WQXN966_Jason
December 28
N4IRS
December 28
WQXN966_Jason
December 27
K4SAT
December 27
Don,
SERVER A rpt.conf
[nodes]
SERVER B rpt.conf
[nodes]
One RPi running ASL 3 RTCMs, all able to reach the RPI via IP.
On 12/28/19 4:16 PM, K4SAT via
K4SAT
K4SAT
              December 28
OK;
So
work?
  1.               I have two RTCM at
N4IRS:
radio interface)
··· (click for more
details)
N4IRS
N4IRS
              December 28
connected radio interface (vs USB connected radio interface)
Visit
Topic
mode.
Ok my second question;
  1. I have two RTCM at those locations, both point to ASL’s servers VIA internet with no other computer required. That will also work? Or do I still need a Pi of my own?
Sent from my Galaxy Tab® A
-------- Original message --------
From: Marshall Oldham via AllStarLink Discussion Groups [email protected]
Date: 12/28/19 3:24 PM (GMT-05:00)
allstar "server’?
Marshall_Oldham
      ASL Admin
    December 28
K4SAT
    December 27
Can this be done with a pair of RTCM’s? Could I have just that hardware with no other “computer” involved. Just plug into a router at one location and another and use the internet?[quote=“Marshall_Oldham, post:2, topic:15728, full:true”] Don, Connecting two nodes together on a private network is a…
You will always need a server somewhere. It can be anywhere if you use rtcm’s but you will need a server no matter what. You dont need the server to be at each repeater site, but it can be there you dont need more then one server if all rtcm connect to it, but you could if you wish have a server per rtcm. server can be a Raspberry Pi. It can be a VPS in a data center. It can be a computer at your house. what ever you want. it just need to be reachable by the rtcm. So you will need to open some ports if the server is behind a firewall. As you can see with the use of rtcm you have a wide variety of possible configuration. But one thing is sure. In case of multicasting you will need them to be linked to only one server as it is the server that do most of the work to synchronise the signal. same for voting receiver. they will need to be connected to a single server.
You will also need a lot more stuff for multicasting, but voting is easier to do and just need simple receiver.
Hope it is more clear now.
Pierre
VE2PF
Pierre
This is why RF guys and IT guys cannot communicate.
ASL has servers.
My question was, simply why do my two RTCM’s need me to provide another server if ASL has a bunch of them?
As I understand it, the servers that ASL operates exist for the purposes of registering repeaters. They do not run as repeaters themselves. The RTCM devices interface to a repeater node through a channel driver, just like the usb fobs do. The only difference is the medium over which they connect and the particular channel driver they use. If you were to use someone else’s ASL installation to interface your RTCM, you wouldn’t really be able to control or configure your repeater because you don’t have access to the ASL installation.
Think of your RTCM as a sound fob (URI) with a network plug for the connection.
Sent: Saturday, December 28, 2019 8:27 PM
K4SAT
December 29
Pierre
ASL has servers.
Pierre_Martel
December 29
Pierre
VE2PF
K4SAT
December 28
N4IRS
December 28
December 28
Yes two or more RTCM’s connected via ASL whether it is a private network or over the internet require a computer or pi running ASL and configured for the RTCMs.
K4SAT
December 28
OK;
So
N4IRS:
radio interface)
I have been a RF guy slightly longer then I have been a IT guy and I communicate with both sides just fine. It seems you don’t understand the word server. Yes, AllStarLink has a bunch of them. Google has a bunch of them. Amazon has a bunch of them. A server “serves” something to a client.
From [https://allstarlink.org/getstarted.html]
"Our architecture provides for 2 organizational entities: 'Servers' and 'Nodes'.
A 'Server' is a computer system at a particular location. On it there may be one or more 'Nodes'.
A 'Node' is a single radio system. There may be more then one 'Node' on a particular 'Server' but most of our users just have one 'Node' attached. A 'Node' may be set up in several different ways. It may be a full-duplex repeater system or several different varieties of simplex operations (a conventional-type transceiver), or a 'hub' which has no radio hardware connected to it whatsoever."
In the case of AllStarLink, YOU need to build a server. This server runs the programs YOU need to run ASL. Your RTCM needs to connect to YOUR server. You can add a second RTCM to YOUR server. You can connect a third RTCM to YOUR server. And so on, and so on.
Steve N4IRS
On 12/28/19 11:26 PM, K4SAT via
K4SAT
K4SAT
              December 29
Pierre
ASL has servers.
Visit
Topic
mode.
