Nodes connected to each other WITHOUT allstar "server'?
Thank you Steve ; Your answer as well as KC1KCC’s are spot on.
It is frustrating to ask the question and be told simply “you need a server” without explaining why a LOCAL: server is required. Part of the problem I find nowhere in the ASL WIKI’s any pictorial examples of a system design and even worse the software libraries are like greek to non-IT folks.
Blockquote
Yea, I am only replying to this old post to close it out with a definite simple answer.
Yes.
Describe the nodes in rpt.conf just like local nodes with the correct IP and port
under [nodes]
The registration nodes list is for changing IP’s and security of the IAX.
When you describe in this direct method, it bypasses all of that.
But it works well if you have specific ecomm connections that are static and/or private network.
