New User - Stuck at Zero Receive Level
Greetings all,
New user here… here’s my setup - Kenwood TM-V71A - URIxB - RPi3.
I can get my radio to key up and play the tones using the simplusb.conf file menu, but i’m not showing any receive audio on the RX adjust.
I’ve made sure to comment in the ‘load simplusb.conf’, radio is set to 1200bps & on VFO A. Just stuck at this point.
Any ideas? Thanks!
Johnny,
Check your simpleusb.conf and make sure of the following settings.
Carrierfrom=usb
Ctcssfrom=**no **
Marshall
From: Johnny Twist via AllStarLink Discussion Groups [mailto:[email protected]]
Sent: Friday, April 03, 2020 7:38 AM
To: [email protected]
Subject: [AllStarLink Discussion Groups] [App_rpt-users] New User - Stuck at Zero Receive Level
Johnny_Twist
April 3
Greetings all,
Any ideas? Thanks!
Hi Marshall,
Ok i’ve updated those settings, still nothing on the RX input levels.
Johnny
Did you try rebooting?
Sent: Friday, April 03, 2020 10:01 AM
Johnny_Twist
April 3
Hi Marshall,
Johnny
In Reply To
KE6PCV ASL Admin
April 3
Johnny, Check your simpleusb.conf and make sure of the following settings. Carrierfrom=usb Ctcssfrom=**no ** 73 Marshall ··· (click for more details)
Previous Replies
KE6PCV ASL Admin
April 3
Johnny,
Carrierfrom=usb
Ctcssfrom=**no **
Marshall
Johnny_Twist
April 3
Greetings all,
Any ideas? Thanks!
Johnny,
Only mentioning this as I had a friend (new to the whole VOIP
concept)when he first attempted to build an Allstar node. He mistakenly
assumed the tune menu generated a RX signal with which to set levels.
When told that he needed an incoming signal from his radio receiver or
some other signal source it was a DUH! moment. Plus it turned out he was
running CTCSS on his receiver which without tone input his RX audio out
was muted.
Not familiar with your radio but do you by any chance have CTCSS turned
on on your receiver?
Larry - N7FM
On 4/3/20 10:00 AM, Johnny Twist via AllStarLink Discussion Groups wrote:
[Johnny_Twist] Johnny_Twist
https://community.allstarlink.org/u/johnny_twist
April 3
Hi Marshall,
Johnny
Visit Topic
https://community.allstarlink.org/t/new-user-stuck-at-zero-receive-level/16730/3
    In Reply To
[KE6PCV] KE6PCV https://community.allstarlink.org/u/ke6pcv ASL Admin
April 3
more details)
https://community.allstarlink.org/t/new-user-stuck-at-zero-receive-level/16730/2
    Previous Replies
April 3
Johnny,
Carrierfrom=usb
Ctcssfrom=**no **
Marshall
April 3
Greetings all,
Any ideas? Thanks!
Visit Topic
https://community.allstarlink.org/email/unsubscribe/23a467ee46dd8807c102efca7c918bc8e40cc61b3594c5cafbd2bd30b016aca0.
Johnny I also forgot to mention since I didn’t see it posted in replies
to you. Don’t forget to restart Asterisk for any edits you make to take
effect. From the terminal command line —> astres.sh
Not treating you like a dummy but you said you were NEW and everyone
forgets at some point while learning.
Larry - N7FM
April 3
Hi Marshall,
Johnny
Visit Topic
    In Reply To
April 3
more details)
    Previous Replies
April 3
Johnny,
Carrierfrom=usb
Ctcssfrom=**no **
Marshall
April 3
Greetings all,
Any ideas? Thanks!
Visit Topic
Good day, everyone!
I am new to AllStar and have the exact same setup as the original poster. I have Kenwood TM-V71A connected to a raspberry pi with a URIxB. I have no receive audio. The radio transmits a test tone without problem, but does not seem to be receiving audio. I have changed the settings as above:
Carrierfrom= usb
Ctcssfrom= no
No affect after reboot. I created my cable using this guide: https://forums.qrz.com/index.php?attachments/din-to-db25-jpg.478998/ found on this forum post: https://forums.qrz.com/index.php?threads/kenwood-tm-v71a-to-uri-pinout-for-allstar-node.623316/
73,
George
KC3AAD
I found the problem. The diagrams in my last post have the audio from the radio going to pin 24 of the URI, which is fine if you are using a 12V input to the URI to power the amplifier, but in my case, I was not. Pin 4 should go to pin 21 on the URI. Audio levels adjusted and everything works as expected.
73,
George
KC3AAD
Marshall, apologize for not following up sooner, I have been busy! Those settings changes worked. My RX audio is still a bit low even set to 950, but that might be the crappy HT i’m using with zero settings for mic gain :confused:
