If your only using one node for now, just keep it as a 5 digit node number.
You can always change later to 6 digit if you need too.
From: JD Delancy via AllStarLink Discussion Groups [mailto:noreply@community.allstarlink.org]
Sent: Friday, May 01, 2020 5:55 PM
To: ke6pcv@cal-net.org
Subject: [AllStarLink Discussion Groups] [App_rpt-users] How to and Sundry
J_D
May 2
Tnx Marshall
No, I'm only working on one node for now. So I assume that I can
convert to six digits optionally but y’all would prefer it
jd
··· (click for more details)
In Reply To
KE6PCV ASL Admin
May 1
Yes that is the thought, we want to conserve 5 digit node numbers so that we do not run out. Due to this COVID 19 thing, and everyone staying home, we are issuing a higher than normal amount of new node numbers this past month. So, if you requested more than 2 node numbers we automatically deny th…
Previous Replies
KE6PCV ASL Admin
May 1
So, if you requested more than 2 node numbers we automatically deny the additional numbers. This is to conserve node numbers so that we do not run out. However, we have a workable solution which will provide up to 20 node numbers. We call it NNX. Please read about NNX nodes on our WiKi at
https://wiki.allstarlink.org/wiki/NNX.
The wiki page explains the very easy process to add additional node numbers without consuming additional resources. NNX also saves you time and assures your numbers are sequential.
If you really need more than 20 nodes please let us know in a message.
Thank you for your cooperation and understanding.
Marshall - ke6pcv
k4sip
May 1
Not really sure. I think it was just to increase availability of nodes overall.
Someone who knows can comment here and set that matter straight.
Byron
J_D
May 1
I tried Bryon (to stay dry)
Another question. Is there a need/requirement for the 5-digit
nodes to move to 6-digit ones to make for more number
availability?
jd
k4sip
April 29
We hope it helped out and you stayed dry in the process!
Byron
J_D
April 20
Thanmks Byron, that gives me something to
learn with on this rainy day
jd
