How to and Sundry
Yes that is the thought, we want to conserve 5 digit node numbers so that we do not run out.
Due to this COVID 19 thing, and everyone staying home, we are issuing a higher than normal amount of new node numbers this past month.
So, if you requested more than 2 node numbers we automatically deny the additional numbers. This is to conserve node numbers so that we do not run out. However, we have a workable solution which will provide up to 20 node numbers. We call it NNX. Please read about NNX nodes on our WiKi at
https://wiki.allstarlink.org/wiki/NNX.
The wiki page explains the very easy process to add additional node numbers without consuming additional resources. NNX also saves you time and assures your numbers are sequential.
If you really need more than 20 nodes please let us know in a message.
Thank you for your cooperation and understanding.
