How to and Sundry
Re-read your last reply again. Here are some more things to consider for monitoring your Node(s).
  1. You can use the Web Transceiver to monitor your Node… (requires Java, is not supported easily by many web browsers anymore… kind of a PITA to get going at first… This is a feature within the AllStarLink portal itself.
    Web Transceiver-capable Nodes are noted with a “wt” character, in this list => https://www.allstarlink.org/nodelist/ (Click the link, get the Web Transceiver for that node, try doing the same on yours?)
  2. You can enable IAXRPT support on your Server Node(s), and then use an app on your phone or computer to listen/transmit on your Nodes without a radio.
    Instructions for that here => https://wiki.allstarlink.org/wiki/Setup_IAXRPT_use
    IAXRPT windows client => http://dvswitch.org/files/AllStarLink/setup_iaxrpt_xipar_010146.exe
  3. You can also Icecast your Node audio out to an Icecast server. (Bit of setup before this works, but its an option) Once you Icecast your node audio, you can listen-only from pretty much any device. I don’t have a good recent thread to point you towards for this one, but there is this one => ices plugin
Good luck,
Byron
