On 3/19/20 8:45 AM, Ryan Matthew Headley via AllStarLink Discussion Groups wrote:
[Ryan_Matthew_Headley] Ryan_Matthew_Headley
https://community.allstarlink.org/u/ryan_matthew_headley
March 19
I have tried several fresh installs, setting everything accord to ALL
the information listed in this thread and others that I have found,
using any port other than 4569 for the X86 image does not work for
incoming connections–even on LAN. The software simply will not listen at
any other port number. I checked iptables and the it does not appear to
be inhibiting anything.
The only workaround I have been able to find that works is port
translation from the router. This requires two separate machines–one for
each node. Both are listening on 4569, but the router sends incoming
from 4569 to 4569 on once machine and 4568 to 4569 on the other.
https://community.allstarlink.org/t/alternate-iax-port/16560/6 or
reply to this email to respond.
[G8HAV] G8HAV https://community.allstarlink.org/u/g8hav
March 18
Hi Ryan,
I have the same problem. 'iax2 show registry ’ command in CLI shows it
is registered but cannot get it to connect.
March 16
These instructions are helpful, but unfortunately do not solve the problem.
https://community.allstarlink.org/t/alternate-iax-port/16560/4
[wd6awp] wd6awp https://community.allstarlink.org/u/wd6awp ASL Admin
March 13
Take a look at this document and be sure to put the bindport= setting
right at the top of the [general] stanza.
wiki.allstarlink.org
https://wiki.allstarlink.org/w/images/0/0c/ASL_two_servers_one_netwrok.pdf
<https://wiki.allstarlink.org/w/images/0/0c/ASL_two_servers_one_netwrok.pdf>
56.62 KB
[larry] larry https://community.allstarlink.org/u/larry
March 13
Ryan,
I encountered this issue once. It must have been a hiccup in the
routing. My solution was to enter the actual node IP in place of the
12.0.0.1’s and reload rpt.conf. Made no sense but it worked after that.
Why it didn’t work the first time using the 12.0.0.1 is beyond me.
With other nodes I tied together the problem never occurred?
Larry - N7FM
https://community.allstarlink.org/t/alternate-iax-port/16560/2
March 13
This does not appear to have been discussed for quite a while. I have
read everything that a search of the thread title shows and performed
all of the recommended solutions, and I still cannot connect from WAN
/or/ LAN.
The situation is this. I am running two Asterisk servers on the same
LAN, but not the same machine. I setup two servers at allstarlink.org
http://allstarlink.org with ports of 4569 and 4568, and have linked
the two nodes to the corresponding servers.
512190 is port 4569
512192 is port 4568
After setting up the physical nodes and setting the proper port
forwarding (I do networking for a living), 512190 (4569) can be reached
from WAN; 512192 (4568) cannot be reached from WAN. Both nodes are
capable of connecting out to WAN.
An Allstar DNS search returns all of the proper information for 512192:
512192 W4EAE Cayce SC DNS DNS radio@172.75.169.33:4568/512192,172.75.169.33
Before going any further, I wanted to make sure than 512192 was
reachable by LAN. It is not. 512190 cannot connect to 512192, but 512192
can connect to 512190.
This tells me that the problem is local to the 512192 (4568) installation.
Here are the pertinent parts of my *.conf files:
iax.conf of 512192:
bindport = 4568
rpt.conf of 512192:
[nodes]
512192 = radio@127.0.0.1 mailto:radio@127.0.0.1/512192,NONE ; This
must be changed to your node number
515190 = radio@192.168.1.160:4569/512190,NONE
rpt.conf of 512190:
512190 = radio@127.0.0.1 mailto:radio@127.0.0.1/512190,NONE
512192 = radio@192.168.1.215:4568/512192,NONE
What am I missing?
To unsubscribe from these emails, click here
https://community.allstarlink.org/email/unsubscribe/786a17ac4ab6b548389ce6897b14ffd34926f94242af726b3bffc6db7ae75045.
