Ryan,
I encountered this issue once. It must have been a hiccup in the
routing. My solution was to enter the actual node IP in place of the
12.0.0.1’s and reload rpt.conf. Made no sense but it worked after that.
Why it didn’t work the first time using the 12.0.0.1 is beyond me.
With other nodes I tied together the problem never occurred?
Larry - N7FM
On 3/13/20 7:10 AM, Ryan Matthew Headley via AllStarLink Discussion Groups wrote:
[Ryan_Matthew_Headley] Ryan_Matthew_Headley
https://community.allstarlink.org/u/ryan_matthew_headley
March 13This does not appear to have been discussed for quite a while. I have
read everything that a search of the thread title shows and performed
all of the recommended solutions, and I still cannot connect from WAN
/or/ LAN.The situation is this. I am running two Asterisk servers on the same
LAN, but not the same machine. I setup two servers at allstarlink.org
http://allstarlink.org with ports of 4569 and 4568, and have linked
the two nodes to the corresponding servers.512190 is port 4569
512192 is port 4568After setting up the physical nodes and setting the proper port
forwarding (I do networking for a living), 512190 (4569) can be reached
from WAN; 512192 (4568) cannot be reached from WAN. Both nodes are
capable of connecting out to WAN.An Allstar DNS search returns all of the proper information for 512192:
512192 W4EAE Cayce SC DNS DNS radio@172.75.169.33:4568/512192,172.75.169.33
Before going any further, I wanted to make sure than 512192 was
reachable by LAN. It is not. 512190 cannot connect to 512192, but 512192
can connect to 512190.This tells me that the problem is local to the 512192 (4568) installation.
Here are the pertinent parts of my *.conf files:
iax.conf of 512192:
bindport = 4568rpt.conf of 512192:
[nodes]
512192 = radio@127.0.0.1 mailto:radio@127.0.0.1/512192,NONE ; This
must be changed to your node number
515190 = radio@192.168.1.160:4569/512190,NONErpt.conf of 512190:
512190 = radio@127.0.0.1 mailto:radio@127.0.0.1/512190,NONE
512192 = radio@192.168.1.215:4568/512192,NONEWhat am I missing?
https://community.allstarlink.org/t/alternate-iax-port/16560/1 or
reply to this email to respond.You are receiving this because you enabled mailing list mode.
To unsubscribe from these emails, click here
https://community.allstarlink.org/email/unsubscribe/f8ef4703045de3673df8a7abcfeca027c488ab3cd0ccb069528fe555fa87ffdf.
