Kevin,
I notice that you do not have “GPS lock” in the 98 output that you showed us.
Try again but allow more time to get GPS lock before using “98”
I use the Garmin 18 puck GPS and I use datefix “2”
If you use my compile and NEMA it should work for you. If you do not get GPS lock then you probably have a hardware or cable or GPS signal problem.
Send full output of debug 32
Chuck
On Tue, Jan 5, 2021 at 6:52 PM Kevin Walsh via AllStarLink Discussion Groups <noreply@community.allstarlink.org> wrote:
| W8khw1
January 6 |
I just finished testing with a Garmin !8 GPS. Still not setting the time correctly.
Enter Selection (1-27,97-99,r,q,d) : 98
S/W Version: 1.54 04/14/2020
System Uptime: 982.2 Secs
IP Address: 192.168.1.10
Netmask: 255.255.255.0
Gateway: 192.168.1.1
Primary DNS: 192.168.1.1
Secondary DNS: 0.0.0.0
DHCP: 1
VOTER Server IP: 0.0.0.0
VOTER Server UDP Port: 667
OUR UDP Port: 667
GPS Lock: 0
Connected: 0
COR: 1
EXT CTCSS IN: 1
PTT: 0
RSSI: 0
Current Samples / Sec.: 0
Current Peak Audio Level: 24
Squelch Noise Gain Value: 35, Diode Cal. Value: 41, SQL pot 179
Last Rx Pkt System time: , diff: 0 msec
Last Rx Pkt Timestamp time: , diff: 0 msec
Last Rx Pkt index: 0, inbounds: 0Press The Any Key (Enter) To Continue
GPS signal lost entirely. Starting again…
GPS Receiver Active, waiting for aquisition
GPS signal acquired, number of satellites in use = 4
Time now syncronized to GPS
| Gregn1
January 6 |
I got the same results as WB6OZD. I’m also using a BG7BTL GPS receiver and using the 1.54 voter board version.
Greg
WB6ZSU
| WB6OZD
January 5 |
No go for me on the update as well. Tried all settings of option 12 (0,1,2,3,4) and get varying “Current Time” showing:
0 - 01/01/1970, time is value from power up
1 - 10/06/1988, 02:43:43
2 - 08/17/1989, time is value from power up
3 - 05/22/2008, 02:43:43
4 - 08/02/2009, time is value from power up
(note that current time was about UTC 23:28 when testing).I’m currently testing with a newer BG7TBL unit, but I have a Garmin I can give a go on as well.
Here’s my status output:
System Uptime: 76.7 Secs
IP Address: 192.168.1.51
Primary DNS: 192.168.1.22
Secondary DNS: 1.1.1.1
DHCP: 1
VOTER Server IP: 192.5.222.90
OUR UDP Port: 667
GPS Lock: 1
Connected: 1
COR: 0
EXT CTCSS IN: 1
PTT: 0
RSSI: 0
Current Samples / Sec.: 8000
Current Peak Audio Level: 53144
Squelch Noise Gain Value: 24, Diode Cal. Value: 44, SQL pot 559
Current Time: Thu Apr 02, 2009 00:01:09.300
Last Rx Pkt System time: , diff: 1679888052 msec
| W8khw1
January 5 |
Thank you for uploading the binary files Chuck! Unfortunately I still have no glory on setting the time, but I am still testing with the QRP Labs GPS module which might be the problem. I am sure that I have some Garmin 18 puck GPS modules around here as well as a Thunderbolt running downstairs. I will give them a try later this evening.
Kevin, W8KHW
My Status output:
GPS signal acquired, number of satellites in use = 3
Warning: GPS Data time period elapsed
Warning: GPS PPS Signal time period elapsed
Time now syncronized to GPSEnter Selection (1-27,97-99,r,q,d) : 98
System Uptime: 73.3 Secs
IP Address: 172.25.36.189
Gateway: 172.25.36.1
Primary DNS: 172.25.36.107
Secondary DNS: 172.25.34.108
DHCP: 0
VOTER Server IP: 172.25.36.89
OUR UDP Port: 667
GPS Lock: 1
Connected: 0
COR: 1
EXT CTCSS IN: 1
PTT: 0
RSSI: 0
Current Peak Audio Level: 40
Squelch Noise Gain Value: 20, Diode Cal. Value: 50, SQL pot 265
| Chuck_Henderson
January 5 |
I just now uploaded the 2 binary files that I use here.
https://github.com/ccie2285/voter/tree/master/board-firmwarethey are
Voter154SMT04-14-20c.cry S/W Version: 1.54 04/14/2020 “CHUCK” for RTCMand
Voter154voter-04-14-20c.cry S/W Version: 1.54 04/14/2020 “CHUCK” for Voter BoardI am using the compiler that I have been using since the beginning back in about 2010 that is running on Windows XP service pack 2 (offline)
It is a pain to get files onto and off of without a network, but I can slowly transfer via USB 2 thumb drives.I only compile versions that I have hardware to test. Both of these files have been running without problems since 4-14-2020, the day I compiled them.
don’t forget to set offline #12 to one of 0, 1, 2, 3, or 4 and save and reboot
Chuck
| WB6OZD
January 5 |
Upon checking additional RTCM’s, I’m finding that I have units both with and without the issue running 1.51 Chuck (8/8/17). I cannot say if they were loaded with the same binary copy of the firmware though. I also have a 1.50 version that does not have the date problem.
I’ll try flashing some tonight with the binary versions I have to see if any builds I have work fine. I have no idea what version of MPLAB was used to build them.
If you guys come up with a specific version that works, I’d be happy to test your binary here on my units as well.
