I just now uploaded the 2 binary files that I use here.
https://github.com/ccie2285/voter/tree/master/board-firmware
they are
Voter154SMT04-14-20c.cry S/W Version: 1.54 04/14/2020 “CHUCK” for RTCM
and
Voter154voter-04-14-20c.cry S/W Version: 1.54 04/14/2020 “CHUCK” for Voter Board
I am using the compiler that I have been using since the beginning back in about 2010 that is running on Windows XP service pack 2 (offline)
It is a pain to get files onto and off of without a network, but I can slowly transfer via USB 2 thumb drives.
I only compile versions that I have hardware to test. Both of these files have been running without problems since 4-14-2020, the day I compiled them.
don’t forget to set offline #12 to one of 0, 1, 2, 3, or 4 and save and reboot
Chuck
On Tue, Jan 5, 2021 at 3:14 PM Jon Welfringer via AllStarLink Discussion Groups <noreply@community.allstarlink.org> wrote:
| WB6OZD
January 5 |
Upon checking additional RTCM’s, I’m finding that I have units both with and without the issue running 1.51 Chuck (8/8/17). I cannot say if they were loaded with the same binary copy of the firmware though. I also have a 1.50 version that does not have the date problem.
I’ll try flashing some tonight with the binary versions I have to see if any builds I have work fine. I have no idea what version of MPLAB was used to build them.
If you guys come up with a specific version that works, I’d be happy to test your binary here on my units as well.
| ve7fet
January 5 |
Hi Kevin,
Yeah, tried compiling it with the legacy libs, and that breaks other stuff.
Lee
| ve7fet
January 5 |
Well, isn’t that interesting.
That begs the question then, which version of MPLAB and more specifically, which version of C30 did you compile that with?
Lee
| Chuck_Henderson
January 5 |
Here is the output of my “98”
Enter Selection (1-27,97-99,r,q,d) : 98S/W Version: 1.54 04/14/2020
System Uptime: 1416.9 Secs
IP Address: 10.10.10.241
Netmask: 255.255.255.0
Gateway: 10.10.10.1
Primary DNS: 8.8.8.8
Secondary DNS: 8.8.4.4
DHCP: 0
VOTER Server IP: 10.10.10.134
VOTER Server UDP Port: 668
OUR UDP Port: 668
GPS Lock: 1
Connected: 1
COR: 0
EXT CTCSS IN: 0
PTT: 0
RSSI: 0
Current Samples / Sec.: 8000
Current Peak Audio Level: 51208
Squelch Noise Gain Value: 106, Diode Cal. Value: 43, SQL pot 167
Current Time: Tue Jan 05, 2021 20:11:32.180
Last Rx Pkt System time: 01/05/2021 20:11:09.760, diff: 22420 msec
Last Rx Pkt Timestamp time: 01/05/2021 20:11:09.760, diff: 0 msec
Last Rx Pkt index: 180, inbounds: 1And here is output from my debug 32
GPS-DEBUG: $GPGGA,201338,4030.0246,N,08855.9307,W,2,09,0.9,254.0,M,-32.3,M,7E
GPS-DEBUG: $GPGSA,A,3,03,04,07,09,16,22,26,27,31,1.6,0.9,1.333
GPS-DEBUG: $GPGSV,3,1,11,03,28,221,34,04,78,296,42,07,12,277,33,08,07,175,2478
GPS-DEBUG: $GPGSV,3,2,11,09,37,311,43,16,80,081,40,22,14,203,34,26,46,051,3574
GPS-DEBUG: $GPGSV,3,3,11,27,27,145,38,29,02,027,25,31,16,082,294D
GPS-DEBUG: $GPRMC,201339,A,4030.0246,N,08855.9307,W,000.0,343.0,220501,002.3,W77
GPS-DEBUG: mon: 4, gps_time: 1609877619, real_time: 1609877619, ctime: Tue Jan 5 20:13:39 2021GPS-DEBUG: $GPGGA,201339,4030.0246,N,08855.9307,W,2,09,0.9,254.0,M,-32.3,M,7F
GPS-DEBUG: $GPRMC,201340,A,4030.0246,N,08855.9307,W,000.0,343.0,220501,002.3,W79
GPS-DEBUG: mon: 4, gps_time: 1609877620, real_time: 1609877620, ctime: Tue Jan 5 20:13:40 2021This tells me that there is nothing wrong with mktime as used in this code.
I do not have a Trimble to test with, but I have a variety of Garmin that each need a different offset to correct them.
| W8khw1
January 5 |
I have a system that has been running for years without requiring any fiddling. I noticed the RTCM’s were running v1.50, so I decided to setup a spare RTCM and test v1.51. The updated version doesn’t report an error, but it also doesn’t set the System Time. I am running one of the QRP Labs GPS devices on the test unit (and also at a couple receive sites). When checking status with menu 98 it reports
I would be happy to test v1.54 and see if that works if the binary was available. I had difficulty getting the compiler working correctly the last time I tried.
Lee, the original link you provided from microchip had a “work around” post in the thread. I believe it mentioned using an alternate library.
Thanks for everybody’s help with this.
Kevin
W8KHW
| ve7fet
January 5 |
Hi Chuck,
I don’t believe that is going to help in this case. I am running a similarly modified firmware (have been testing a number of similar changes to what you have in that branch), and they were all running fine, until we rolled over on NYE.
The problem isn’t a week rollover issue, it is a bug in the mktime routine, causing it to return -1 when you send it the tm struct to convert to epoch time.
That causes gpstime to be -1, so, it always starts counting at something like Dec 31, 1970 at 1600 (I can’t recall the exact time off the top of my head).
So, resetting the GPS, always causes it to start counting from that date, regardless of what the real date/time is.
At least, that is what I am seeing on both the TSIP (Trimble) and NMEA devices I have access to, they’re both behaving the same (and were previously working just fine).
I think the fix will be to convert the date/time from the GPS to epoch with a stand-alone function, that doesn’t use the built-in mktime from time.h.
Unfortunately, the box I was using to compile test code on decided to blow up (thanks Microsoft updates), so I haven’t had a chance to compile and test a fix, yet.
Lee
