I have a simoco node radio interfacing with a KL450 repeater. I have set duplex=0 to remove telemetry but still get the link/unlink announcements. I can manage when I want these announcements by disabling/enabling telemetry.
But this also prevents me from calling saytime… i.e. duplex=0 prevents saytime. I can’t go to duplex=1 or higher because I get looping. So being stuck with duplex=0, I still wish to force a saytime call from crontab.
How do I force a ‘saytime’ announcement with suplex=0?
However, if that does not bring you to where you want, come back and ask more.
But do tell us what version of software you are using if you do.
ASL/hamvoip/beta etc
Status 12 plays the time locally. Assuming you only want the time announcement on your repeater this might work. Try the command below. Replace 1234 with your node number. The xxx is just junk rpt cmd needs.
asterisk -rvvv
rpt cmd 1234 status 12 xxx
Do you hear the time announcement and/or see it printed on the screen?
yes - I’d love to get rid of the ping ping and return to dupex=1… but I am yet to get the repeater manager to install a different controller to eliminate/drop the Tx tone when identing… so things will change shortly anyway… still I’d like to learn more
I still get silence - no time announcement. I get this but no Tx occurs:
AllStarNodeCLI> rpt cmd 512810 status 12 xxx
– <DAHDI/pseudo-202651003> Playing ‘rpt/goodmorning’ (language ‘en’)
– <DAHDI/pseudo-202651003> Playing ‘rpt/thetimeis’ (language ‘en’)
– <DAHDI/pseudo-202651003> Playing ‘digits/10’ (language ‘en’)
– <DAHDI/pseudo-202651003> Playing ‘digits/50’ (language ‘en’)
– <DAHDI/pseudo-202651003> Playing ‘digits/4’ (language ‘en’)
– <DAHDI/pseudo-202651003> Playing ‘digits/a-m’ (language ‘en’)
– Hungup ‘DAHDI/pseudo-202651003’
AllStarNodeCLI>
I guess “no telemetry means no telemetry” is really, really true. But I thought it was worth try.
So you are stuck with duplex=1 if you want time announcements. Next suggestion is to try these settings to see if you can get rid of the looping:
duplex=1
nounkeyct=1 ; Set to a 1 to eliminate courtesy tones and associated delays.
telemdefault = 0 ;No Linking messages
hangtime = 0 ;No hang time
;idrecording = myvoiceid ;No IDs
;idtalkover = |iW1AW ;No talkover ID
Thanks Tim,
but it’s duplex=0 that I’m stuck with not 1 (1 causes looping)
I’m setting nounkeyct=1 and trying that.
Can you tell me the difference between having idrecording and idtalkover commented out and actually set to nothing? Is there a difference at all?
Alan
Sorry, I communicated poorly. I’m suggesting you must use duplex=1 in order to have the time announcement. However, with the settings from the previous post you may be able to remove the courtesy tones and looping.
Great! Glad nounkeyct=1 and duplex=1 solved the problem. These other settings are recommended as well, particularly hangtime=0. The repeater users will thank you
Just for the record… for follow up’s…
With some settings that you might comment out, there may be a default setting when one does not exist. Setting it to “” nothing prevents that.
But I can’t tell you which ones. And they may have changed since I first noticed that with the old ACID version.
