I started seeing many of this error every few seconds.
kernel: [18199.563495] retire_capture_urb: 2 callbacks suppresse
Anyone have a hint of fix?
Rich
Rich
Rich,
you might mention the version of the software you are running and the OS if other than default.
Mike,
Sorry for delay. It is the default asl node load. I have run the update and upgrade functions at monthly intervals. Not sure if it started after updates or before…
Rich
Is this a Pi or PC ?
ASL 1.01 or beta 6 ?
Manual install or from IMG ?
Mike,
It is an HP PC running ASL 1.01. I installed it using the posted IMG file. Other than the tons of error messages, it runs fine.
Rich
Best I can give you is a hint, I believe it’s a USB error.
I suggest you Google “retire_capture_urb: 2 callbacks suppressed”
