JD,
I wish that I had better news to report.
The development has died down with new Pi image version of Allstarlink that was being tested and worked on.
The folks that were working on it have been pretty quiet over the past few months, so I am not sure if anything is being done currently for the new release.
There are several updates that have been made to Allstarlink software and there is a pre-release of ASL 1.02 on github.
You can still use the latest pre-release of ASL 1.02 to compile your own software, but there are no pre-made images yet.
NOTE: About the Raspberry Pi-4. Although this is a great piece of hardware and will be great for running a single USB on a Pi-4 Allstarlink node.
There remains a MAJOR problem with the Pi 4 Linux Kernel and not the app_rpt code. This causes issues when you use more than one USB sound fob with the Raspberry Pi-4 board.
This issue seems to be bug in the Raspbian OS USB driver code for the Pi 4 hardware only. Other boards such as the Pi-3b+ seem to work.
Marshall - ke6pcv
From: JD Delancy via AllStarLink Discussion Groups [mailto:noreply@community.allstarlink.org]
Sent: Wednesday, September 02, 2020 9:50 AM
To: ke6pcv@cal-net.org
Subject: [AllStarLink Discussion Groups] Six Digit Conversion
J_D
September 2
thanks Marshal. Done, now six digits
Other question. Is the new version of Allstar still in testing or has been released to production and I missed the announcement. I’ve been holding back on acquiring a RaPI-4 since the new version looked immenint amd the current version of Allstar version won’t play on it
jd
··· (click for more details)
In Reply To
KE6PCV ASL Admin
August 25
JD, For the NNX number upgrade you can run items 1 and 2 on the ASL menu and update the the node number information and registration password. If you already have a node number that was 5 digit you can manually update the following files in this directory /etc/asterisk/. rpt.conf extensions.conf …
Previous Replies
J_D
August 25
Thanks Marshall
KE6PCV ASL Admin
August 25
JD,
rpt.conf
extensions.conf
iax.conf
simpleusb.conf (whatever channel driver you are using)
You will need to change the node number from XXXXX to XXXXXY in these
four files.
You may also have the edit the registration statements and passwords as well.
Restart asterisk.
You can use a search and replace to find and update the node number.
Marshall - ke6pcv
wd6awp ASL Admin
August 25
Yes, there are changes to the config files. There is a howto here https://wiki.allstarlink.org/wiki/NNX.
J_D
August 25
Tnx Russell – are the files to change rpt.conf, extension. conf and iax.conf? Any others?
KV4S
August 24
JD,
If you log into your AllstarLink.org account and in node setting there is an option convert a node or multiple based on how many you can select.
Press Continue to:
· Request a new node number from AllStarLink.
· Extend a node number up to 10 nodes.
· Delete a node number.
