I have been trying to install ALS to run a node on a VirtualBox. I have an RA-25 connected to the PC and an FT8900 for my radio. But when I got to the SimpleUSB-tune-menu config step, an error is reported saying “There was an error running option 4”.
I initially thought that the VirtualBox is causing the problem. So I took an old laptop out that I configured to do a dual-boot (Win8 and Debian 9) and did the install there. I had exactly the same error.
Could any one please point me to where I should be looking to resolve the issue, other than getting a Raspberry Pi? Any help is much appreciated.
Be sure that you have enabled SimpleUSB in modules.conf Also, that sounds line you are using the ASL menus. Try exiting the menu and run it on the Linux CLI with simple-tune-menu.
Ok, that’s good. So that being the case, there is some problem with the settings in rpt.conf and/or simpleusb.conf. Rpt.conf has to point to a stanza of the same name in simpleusb.conf.
Ahha! Dahdi is the problem. That’s the most difficult problem to fix. My recommendation is to get a Raspberry Pi. But maybe one of the other folks on here is willing to help you with DAHDI on VirtualBox or dual boot.
DAHDI is a critical part of Asterisk drivers. There is no menu anything for dahdi. It’s must be compiled for the kernel in use.
This Topic discusses the issue:
If you did manage to compile dahdi and get Asterisk running it’s questionable that VirtualBox would talk to the USB port reliably if at all. You’d have a better chance with Dual boot.
Thanks for the info. I was hoping that following the beginner’s guide and running the installer was all that was needed to get the node up and running.
If DAHDI is a critical part of Asterisk drivers, is it correct to say that it is part of the installer package found in the Downloads page? If it is, what may have caused DAHDI to be not installed on my PC? I have downloaded and ran the installer several times, still no luck.
