Problems using the make command
Very frustrated when I’m not permitted to post my questions about this problem when “new users can’t have more than two links in a post”. So much for support.
So just describe it and perhaps we can help
I have been attempting to create a full-duplex node as was done by NR9V, using 2 Retevis RT85 handhelds and a Masters Communications DRA-30 radio interface. He has his set up for vox on the receive side of it, and I am able to get it working that way. The reason for using VOX is that it makes it simple and non-invasive to the receive radio, not having to open it up and find a place to tap a COS line into it. The problem is that the vox hangtime is excessively long (2000ms). His setup has a hangtime of 500ms. I have repeatedly tried and failed to install his re-coded version of ASL which changes the hard-coded voxhangtime perimeter. I follow the procedures including getting the ASL repo, the dependencies, running apt update and apt upgrade, running the git clone command, and then ./configure. When I run the “make” command it proceeds to a certain point then fails. The same thing happens when I try the git clone GitHub - AllStarLink/ASL-Asterisk: Version of Asterisk used for AllStarLink command. The make process always fails. I have tried to do this from an image flashed using Raspberry Pi Imager and using their Debian Bullseye with no desktop.
I began from scratch- flashing 2.0.0 beta 6 to a micro SD card, then following the instructions for
These are the errors during the “make” process:
/root/ASL-Asterisk/asterisk/main/utils.c:1390: undefined reference to `pthread_setspecific’
collect2: error: ld returned 1 exit status
make[1]: *** [Makefile:142: asterisk] Error 1
make[1]: Leaving directory ‘/root/ASL-Asterisk/asterisk/main’
make: *** [Makefile:361: main] Error 2
Hi Michael, thanks for posting that error message. ASL did make a change involving pthreads a few weeks ago. Here is the link to my fork of the branch from prior to that:
https://github.com/AllStarLink/ASL-Asterisk/archive/24cdbdc0b235122a8cd8502a5bf7f749ba9c1c9b.zip
If you replace the git clone line in the build instructions with a wget and unzip of the above it should fix that and voxhangtime cfg in usbradio.conf will be supported. LMK how it goes.
If you already did the various update commands on your node you would just need to do the following:
UPDATE: See updated instructions in post from Dec. 23. Building from a zip may not work since git files are not present
cd ~
wget https://github.com/AllStarLink/ASL-Asterisk/archive/24cdbdc0b235122a8cd8502a5bf7f749ba9c1c9b.zip
unzip 24cdbdc0b235122a8cd8502a5bf7f749ba9c1c9b.zip
mv ASL-Asterisk-24cdbdc0b235122a8cd8502a5bf7f749ba9c1c9b ASL-NR9V
cd ASL-NR9V/asterisk
./configure
make
sudo su # if not already logged in as root
make install
I just tested these steps and got no errors. Let us know how it goes.
This stupid rule with limiting the number of links in a post is completely ridiculous. I can’t post the output from my attempt to download that file but in short it is unable to resolve the host address.
It finally downloaded. During the make process I get the following errors:
menuselect/menuselect --check-deps menuselect.makeopts
Generating embedded module rules …
fatal: not a git repository (or any of the parent directories): .git
make[1]: Entering directory ‘/home/repeater/ASL-NR9V/asterisk/utils’
Hi Michael, not sure why there would be a ‘git’ error during a make, maybe the make file is trying to pull in a git version number or something like that. Anyhow it appears that no matter how or what you try to compile you’re getting errors. I think the first step is to go back to the latest beta release and try to compile that following the instructions on the ASL github readme, ie.:
git clone https://github.com/AllStarLink/ASL-Asterisk.git
cd ASL-Asterisk/asterisk
./configure
make
make install
2 other notes:
  1. You can post all the text, logs etc. you like if you use the “</>” button on the toolbar to format it as 'code'. That will prevent urls from showing up as links or the forum software assuming you are a spammer.
  2. I would post the results of the above here: ASL-2.0.0-beta.6 Ready for Download - #12 by k6jwn. This was posted by the devs and I suspect they might like to know if someone is unable to compile the code.
Should be a simple matter to then resolve that and at that point it’s literally just 1-line of code to change the VOXHANGTIME #define in xpmr.c.
(BTW I just got a microscope and am going to try soldering a COS wire onto an RT85 soon as it should be pretty easy to do and would simplify the cfgs a bit. I have no issue with a 500mS or even 1S voxhangtime (always good to leave a bit of space before and after your audio anyway) but if I can open an RT85 and solder a wire on in 10 minutes then the default ASL config with simpleusb would be all that’s needed. Will let you know how that goes.)
This time I began with flashing the beta 6 image on a re-formatted micro SD card. Booted up the system
and did not enter asl-menu to do any setup. Followed the Prerequisite Steps on the github page, followed by the git clone line from your last post. No errors until the make install command and saw the following:
/home/repeater/ASL-Asterisk/asterisk/main/utils.c:1390: undefined reference to `pthread_setspecific’
make[1]: Leaving directory ‘/home/repeater/ASL-Asterisk/asterisk/main’
Something is wrong in line# 142 in “asterisk” as well as line# 361 in “main”. I have also tried the preliminary steps on the github page after going through the setup process in asl-menu. At that time I
was thinking that perhaps some files being in use, such as usbradio.conf and its associated drivers, was causing the errors.
David, is it possible to get a fresh image that already includes the changed voxhangtime setting rather than repeatedly attempting to compile the updated file?
Also, I would indeed be curious as to where you’re tapping the COS line inside the RT85. Simple enough to use pin 2 of the DB-9 connector on the DRA-30. And if there are three contacts on the audio jack of the radio it would be easy to disconnect the existing radio circuit from its “ring” contact and re-purpose it for the COS. The 2.5mm audio cable I’m using is a 3-foot cable I purchased on Amazon and cut it in half. My DB-9 plug is actually a breakout plug making the use of the terminal blocks a great alternative to soldering. As for working on SMT circuit boards I got very good at replacing 168-pin fine-pitch “chips” using a 1/64" solder tip, solder paste and a 10x jeweler’s loupe.
I was able to duplicate the compile error KE7MT saw with latest ASL 2.0 Beta on an RPi 4 and will post on the other thread I mentioned that this has occurred for 2 people and I’m sure they’ll take care of that soon.
Here are updated instructions on how to compile the known-working ASL 2.0 Beta build (date Nov. 17, '22) with my pull request that makes the voxhangtime a cfg parameter settable in usbradio.conf:
mkdir ASL-voxhangtime-20221117
cd ASL-voxhangtime-20221117
git init
git remote add origin https://github.com/davidgsd/ASL-Asterisk.git
git fetch origin 24cdbdc0b235122a8cd8502a5bf7f749ba9c1c9b
git reset --hard FETCH_HEAD
cd asterisk
./configure
make
sudo make install
I confirmed this compiles fine on my RPi4. I could also post the resulting build files but the above instructions are pretty simple and probably 10 times easier than trying to manually install all the build files.
This seems to be working, but after the squelch tail something else is keeping the node keyed for at least 2 seconds. There must be something else in the ASL files besides the two perimeters in rpt.conf, which I have turned all the way down to 5ms each.
Do you have all the following settings?
Recommended usbradio.conf settings:
rxboost = 0
rxctcssoverride = 1
carrierfrom = vox
voxhangtime = 500
ctcssfrom = no
rxdemod = speaker
txprelim = no
txlimonly = yes
txtoctype = no
txmixa = no
txmixb = voice
rxlpf = 2
rxhpf = 1
txlpf = 1
txhpf = 1
duplex = 1
Recommended rpt.conf settings:
Your node number (should have been set in asl-menu/initial setup)
rxchannel = Radio/usb_[node#] ; Comment out all other rxhannel lines
duplex = 3
hangtime = 100
althangtime = 100
linkunkeyct = none ; prevent extra courtesy tones and hang time
nounkeyct = 1
parrotmode = 1 ; 1 = Parrot On Command
Uncomment following lines:
921 = cop,21 ; Enable Parrot Mode
922 = cop,22 ; Disable Parrot Mode
Also check that you have the following RT-85 settings:
I verified the settings on the radio and the two changes I had to make didn’t have any effect. I am hearing the squelch tail ~500ms after unkeying but for some reason the DRA-30 is still in transmit mode- at least the red LED continues to be illuminated for about 1 second and an additional ~1 second after that, according to what I am monitoring on the output of my simplex node. Sure wish Oops (UPS) had delivered my replacement RT85 as was schedule today but the Montana weather…
When in full-duplex (duplex=3 in rpt.conf (not 4)) the hang time on the local RF TX is longer, but the node is not actually transmitting audio to the network during that extra time (beyond when RX CD dropped). Since you’re hearing the squelch tail after ~500mS it sounds like it’s working exactly as it should :slight_smile: It probably just stays keyed a bit longer to prevent more squelch tails, and because it can – it’s full-duplex thus you can key up anytime without having to wait for the node Tx to unkey, so it appears ASL/App-rpt took that into consideration and is making it work a little more like a repeater in this case, giving you a little extra hang time after each TX is complete so if you key up or a remote node keys up there’s no unnecessary carrier drop and extra squelch tail.
Thus I think you’re good to go. You could log into asterisk (sudo asterisk -vvvr) and enable some of the extended debug messages and see if it says any more info about what it’s doing…
p.s. - I couldn’t get any useful timing data from the asterisk menu manually so I set up a script to get the rpt keyed vars from asterisk every 50mS, then keyed up just for a fraction of second, enough to trip CD. Results:
time 1671868925.527  [cos_keyed] => 1  [tx_keyed] => 1
time 1671868926.803  [cos_keyed] => 0  [tx_keyed] => 1 => diff: 1200 mS
time 1671868929.321  [cos_keyed] => 0  [tx_keyed] => 0 => diff: 2500 mS
That sounds like about what you’re seeing and it works great for me. The extra 1.2 secs of space is not noticeable or annoying during a normal QSO on a repeater, where there’s already several seconds of hang time and a courtesy tone. When voxhangtime was 2000mS (vs. 500mS now) it was much more noticeable though and the time to drop COS was closer to 3 seconds.
hangtime=2000
This timer keeps a repeater in tx for the length of time specified in miliseconds past valid cos drop.
Example here 2 seconds.
hangtime=0 may be desired depending on exactly what you are doing. but especially in simplex operations.
may not be valid in all duplex modes.
I finally received my replacement RT85 and have the duplex node up and running. The only problem I have been encountering is the audio from the transmit HT cuts out. At first I thought it was my Internet connection so I switched over to my simplex node. Whatever the problem is, it is related to the transmit side of the duplex node.
Edit: I disconnected from the “hub” of my go-to ASL network and tried a couple extended parrot transmissions and there is no audio disruption. This only happens during the voice telemetry and while receiving when connected to the “hub”. I also swapped HTs and reprogrammed them accordingly, trying to eliminate a bad audio jack. The problem persists. Not sure if there may be some clipping because the telemetry and received transmissions seem to be a little on the “hot” side.
The audio can sound distorted and like it’s cutting out if too loud. HTs are set up for mic-level signals coming in (eg. ~10mV) so you need some significant attenuation from a line-level output. Setting the audio level into the node is easy using the tune utility’s level meter, but on the node’s Tx audio you just have to set it where it sounds the best, or record in an SDR or another radio and then check the levels / clipping / deviation.
Also, make sure all your port settings match on the ASL site for both the server and the node, and that those match the port settings in iax.conf (bindport), rpt.conf ([node#] = radio@ip:port…), and in your router/cable modem.
This is 5 different places the port has to be set. If it’s your first node then you probably have the default of 4569 and didn’t need to change anything, but if it’s not your first node then you have to use a different port number (eg. 4570, 4571, …), and make sure all those places have the same setting and that your router/cable modem has a port forwarding rule to forward traffic on that port# to your node. The node can still look like it’s working if those settings don’t match but the audio will then be more likely to have stuttering/dropouts.
p.s.- There is actually a 6th place the port number has to be set - in the node’s firewall. The ASL-menu’s security options let you enable an iptables firewall and fail2ban, which should always be done. But it might go with the default port num instead of what you actually want.
Yep, that was the problem. It’s been so long since I added a node it didn’t occur to me that there may be a port number issue.
The only problem I have now is an apparent ground loop in the DC supply. Both RT85s are on battery eliminators. My Alinco power supply has one mobile power port, so I am using a “Y” adapter to give me two mobile power ports. There is noise (a lot of hiss) on the output of the node when it is transmitting but when I remove the battery eliminator from the receive radio and put it on battery, the hiss goes away and the output of the node is full quieting.
