On March 9 2017 node 45615 was set up with the following configuration for a Iphone. It works fine.
I can’t seem to set up a new node with the latest image for an Iphone. Can someone give me an example of how using the same information below.
Wayne WA5LUY
IAX. CONF
; Iphone IAX connection
[myiphone]
username=wa5luy
type=friend
context=myphone
host=dynamic
auth=md5
; add a passsword of your selection for secret
secret=xxxxxx
disallow=all
allow=ulaw
allow=g726aal2
allow=gsm
codecpriority=host
transfer=no
; add your call or your selection for callerid
callerid=45615
EXTENSIONS.CONF
[myphone]
;Settings for Zoiper
exten => 45615,1,answer() ;Change the node number on all these lines to your own node
exten => 45615,n,Playback(rpt/node)
exten => 45615,n,Playback(digits/4) ; change the playback digits to your node as well
exten => 45615,n,Playback(digits/5)
exten => 45615,n,Playback(digits/6)
exten => 45615,n,Playback(digits/1)
exten => 45615,n,Playback(rpt/connected)
exten => 45615,n,rpt(45615|Pv) ; Change both numbers here to your node
