I think they’re known. In rpt.conf, I have:
[nodes]
27154 = radio@127.0.0.1:4569/27154,NONE ; This must be changed to your node number
; and iax port number if not the default
1990 = radio@127.0.0.1:4569/1990,NONE
;1998 = radio@127.0.0.1:4569/1998,NONE
;1997 = radio@127.0.0.1:4569/1997,NONE
I can connect from 27154 to 1990, but not the other way around.
Here’s my tlb.conf.
[tlb0]
call=AS27154 ; Call of the app_rpt station
port=44966 ; Start of UDP port range (this port, port + 1)
astnode=27154 ; app_rpt node associated with this instance (for incoming connections)
context=radio-secure ; Asterisk context for incoming connections
codec=ULAW ; Default CODEC to be used
[tlb1]
call=AS1990 ; Call of the app_rpt station
port=44968 ; Start of UDP port range (this port, port + 1)
astnode=1990 ; app_rpt node associated with this instance (for incoming connections)
[nodes]
1001 = REF9550,44.190.8.10,44966,ULAW ; This one is for VK3RIR at ip 12.34.56.78:44966 default CODEC
1002 = REF9556,44.190.8.6,44968,ULAW ; Link to HAM conference, ULAW CODEC
And extensions.conf is the one I understand the least. I have the usual changes to enable routing to private nodes, but don’t know if I need anything else to be able to dial out from private nodes.
[general]
static = yes ; These two lines prevent the command-line interface
writeprotect = yes ; from overwriting the config file. Leave them here.
[globals]
HOMENPA = 999 ; change this to your Area Code
NODE = 27154 ; change this to your node number
NODE1 = 1990 ; First private node (link to HAM)
NODE2 = 1998 ; Second private node (link to P25)
NODE3 = 1997 ; Third private node (link to DMR and YSF)
NODE4 = 1995 ; Fourth private node (link to PTTLink)
[default]
exten => i,1,Hangup
[radio-secure]
exten => ${NODE},1,rpt,${NODE}
exten => ${NODE1},1,rpt,${NODE1}
exten => ${NODE2},1,rpt,${NODE2}
exten => ${NODE3},1,rpt,${NODE3}
exten => ${NODE4},1,rpt,${NODE4}
