Cannot be more sure then that, its the only ide connector and the flash drive can’t be put in slave mode…
Sent: Sunday, December 25, 2011 10:50 AM
To: petem001@hotmail.com ; app_rpt mailing list
Subject: RE: [App_rpt-users] Limey Linux on a HP T5630 Thin Client
well, for whatever its worth, are you at least sure that you
have the flash drive plugged into the IDE0 slot?
To: app_rpt-users@ohnosec.org
Date: Sun, 25 Dec 2011 10:49:50 -0500
Subject: Re: [App_rpt-users] Limey Linux on a HP T5630 Thin Client
Thnaks Jim, I do have a VIA MB, looks like it wont work…
too bad…
Now If those 4 gig flash drive would arrived it would be fun…
ordered them on the 2nd of december… still nothing … Grrinnn!!
Sent: Sunday, December 25, 2011 10:46 AM
Limey only supports VERY specific motherboards. The “via” version is ONLY
for a couple of VIA motherboards.
JIM
Date: Sun, 25 Dec 2011 10:43:36 -0500
Ok, so its not something about the uri.
what could it be?
Sent: Sunday, December 25, 2011 10:27 AM
it has nothing do with the URI at all.
Besides, DONT USE ONBOARD AUDIO. Its quality is NOT ACCEPTIBLE.
JIM WB6NIL
Date: Sun, 25 Dec 2011 00:49:48 -0500
Finally got Limey on the machine…
(Did it with ubuntu live cd , took sometime to figure out where the damn drive was hidden but I got it…)
Limey wont boot properly, it stop at :
isapnp:No plug & Play device found
So from what I understand, since it wont see a URI connected to the machine, it wont continu booting.
I dont want to use a URI i want to use the onboard audio and the onboard serial port for ptt/cor… too bad, will have to find something else…
Unless someone ahve a solution ;-))))
that would be a very nice xmass present ;-))
Pierre
VE2PF
Sent: Saturday, December 24, 2011 11:21 PM
To: pete M
Cc: APP RPT
I built a ribbon cable with two 44 pin connectors on it for just that task. That way I can use my Mac. On CentOS I’m not sure where your removable media will be… maybe in /dev/disk/something?
Tim
:wq
On Dec 24, 2011, at 11:27 AM, pete M wrote:
ok ,
I have some problem here…
Since my t5630 flash drive have a connector that is exactly like the connector that usely is on the end of a ide 44 pin cable I cant connect it to my usb adaptor and dd the limey image to the flash drive.
so I have to do it from the machine itself.
so to do so I downloaded ubuntu live cd to boot from a dvd reader and I have limey tar file on a usb stick.
I try to find where the hell in monted the damn ide flash disk and just cant… I do have an Icone on the desktop but its a symlink and cant find where its pointing…
So I am right now downloading the centos 5.5 live dvd, hoping it will be more clear where the damn thing is…
I tried ide0 no go, ide1 not better…
Anyone can help??
And By the way
Have a merry Xmass to everyone on the list
Pierre Martel
VE2PF
Sent: Wednesday, December 21, 2011 3:55 PM
The probably easiest way to get an answer to your question is to determine
it emperically. Download the following image:
http://stats.allstarlink.org/limeylinux/downloads/cfimg-i586-via-1.1.5.tar.gz
and IMAGE copy it (after un-tarring) to the flash drive (using dd or equivalent).
If it boots, and “talks” to the ethernet, etc, then it works.
Otherwise, it doesnt.
JIM WB6NIL
Date: Wed, 21 Dec 2011 15:46:27 -0500
Subject: [App_rpt-users] Limey Linux on a HP T5630 Thin Client
I Have a few T5630 thin client that was donated to me (spec: 1ghz CPU , 1 gig of ram, 1 Gig flash drive)
they have a VIA chipset that have Video , network, and audio device
I am wondering if I could use that thin client with Limey to do a Allstar node AND an echolink node…
I would connect that to port 3 of my rc210 controler that I have for my 2 M and 70 cm repeater’s.
If possible, how to i build the thing??
I know a few thing about Linux but I am no way a guru… I do prefer a windows machine, but I know that Linux in more stable…
So is it possible or am I dreaming?
forgot to tell you that there is a serial and printerl port to the machine
you can see the spec there:
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c01571963/c01571963.pdf
Pierre
VE2PF
_______________________________________________ App_rpt-users mailing list App_rpt-users@ohnosec.org http://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users
_______________________________________________ App_rpt-users mailing list App_rpt-users@ohnosec.org ohnosec.org
