You seem to dislike every onboard audio device…
are they all bad?
Sent: Sunday, December 25, 2011 6:35 PM
To: petem001@hotmail.com ; app_rpt mailing list
Subject: RE: [App_rpt-users] Limey Linux on a HP T5630 Thin Client
well, as long as you have no intentions of using the built-in audio
for connection to a radio on an Allstar node…
JIM
To: app_rpt-users@ohnosec.org
Date: Sun, 25 Dec 2011 18:30:48 -0500
Subject: Re: [App_rpt-users] Limey Linux on a HP T5630 Thin Client
nope, too bad…
got my tc1100 working, Its a tablet pc that have wifi/bluetooth/lan/modem/usb 1.0 and touch screen that run on 5 volt it even have a KB attach to it… and of course it have sound… 3 jack one for mic one line in and one for speaker… I have hope that this could work…
I have a 20 gig hd in there… but i dont think it will last long… I can hear it click from time to time…
I will order a ide 44 pin to cf adaptor and a 4 gb flsh drive… this will fit in the case and will work I am sure… but I will do my test with the hd first…
just in case I cant make it work
Sent: Sunday, December 25, 2011 6:19 PM
i dont suppose you have some sort of KVM device that supports remote access??
Date: Sun, 25 Dec 2011 17:45:24 -0500
got 8 of the t5630 to play with…
plus a t5730 and a hp t1100 tablet… all free…
So I will work on all this for fun,hoping to do crazy thing with such cute hardware
Sent: Sunday, December 25, 2011 5:42 PM
To: pete M
I tried doing the same on one of the thin clients. A friend gave it to me as she was no longer using it for MagicJack. It had the fast processor, 512MB flash drive and 512MB RAM. has no trouble installing LL but would not boot. Did not really expect it to. I gave the computer to some one else to use with a Magic Jack after reinstalling WinXPe (Windows XP embedded). Don’t have time to really mess with it.
On Sun, Dec 25, 2011 at 9:58 AM, pete M petem001@hotmail.com wrote:
Cannot be more sure then that, its the only ide connector and the flash drive can’t be put in slave mode…
Sent: Sunday, December 25, 2011 10:50 AM
well, for whatever its worth, are you at least sure that you
have the flash drive plugged into the IDE0 slot?
Date: Sun, 25 Dec 2011 10:49:50 -0500
Subject: Re: [App_rpt-users] Limey Linux on a HP T5630 Thin ClientThnaks Jim, I do have a VIA MB, looks like it wont work…
too bad…
Now If those 4 gig flash drive would arrived it would be fun…
ordered them on the 2nd of december… still nothing … Grrinnn!!
Sent: Sunday, December 25, 2011 10:46 AM
Limey only supports VERY specific motherboards. The “via” version is ONLY
for a couple of VIA motherboards.JIM
Date: Sun, 25 Dec 2011 10:43:36 -0500
Subject: Re: [App_rpt-users] Limey Linux on a HP T5630 Thin ClientOk, so its not something about the uri.
what could it be?
Sent: Sunday, December 25, 2011 10:27 AM
it has nothing do with the URI at all.
Besides, DONT USE ONBOARD AUDIO. Its quality is NOT ACCEPTIBLE.
JIM WB6NIL
Date: Sun, 25 Dec 2011 00:49:48 -0500
Subject: Re: [App_rpt-users] Limey Linux on a HP T5630 Thin ClientFinally got Limey on the machine…
(Did it with ubuntu live cd , took sometime to figure out where the damn drive was hidden but I got it…)
Limey wont boot properly, it stop at :
isapnp:No plug & Play device found
So from what I understand, since it wont see a URI connected to the machine, it wont continu booting.
I dont want to use a URI i want to use the onboard audio and the onboard serial port for ptt/cor… too bad, will have to find something else…
Unless someone ahve a solution ;-))))
that would be a very nice xmass present ;-))
Pierre
VE2PF
Sent: Saturday, December 24, 2011 11:21 PM
To: pete M
Cc: APP RPT
I built a ribbon cable with two 44 pin connectors on it for just that task. That way I can use my Mac. On CentOS I’m not sure where your removable media will be… maybe in /dev/disk/something?
Tim
:wq
On Dec 24, 2011, at 11:27 AM, pete M wrote:
ok ,
I have some problem here…
Since my t5630 flash drive have a connector that is exactly like the connector that usely is on the end of a ide 44 pin cable I cant connect it to my usb adaptor and dd the limey image to the flash drive.
so I have to do it from the machine itself.
so to do so I downloaded ubuntu live cd to boot from a dvd reader and I have limey tar file on a usb stick.
I try to find where the hell in monted the damn ide flash disk and just cant.. I do have an Icone on the desktop but its a symlink and cant find where its pointing..
So I am right now downloading the centos 5.5 live dvd, hoping it will be more clear where the damn thing is..
I tried ide0 no go, ide1 not better…
Anyone can help??
And By the way
Have a merry Xmass to everyone on the list
Pierre Martel
VE2PF
Sent: Wednesday, December 21, 2011 3:55 PM
The probably easiest way to get an answer to your question is to determine it emperically. Download the following image:
http://stats.allstarlink.org/limeylinux/downloads/cfimg-i586-via-1.1.5.tar.gz
and IMAGE copy it (after un-tarring) to the flash drive (using dd or equivalent). If it boots, and "talks" to the ethernet, etc, then it works.
Otherwise, it doesnt.
JIM WB6NIL
Date: Wed, 21 Dec 2011 15:46:27 -0500
Subject: [App_rpt-users] Limey Linux on a HP T5630 Thin ClientI Have a few T5630 thin client that was donated to me (spec: 1ghz CPU , 1 gig of ram, 1 Gig flash drive)
they have a VIA chipset that have Video , network, and audio device
I am wondering if I could use that thin client with Limey to do a Allstar node AND an echolink node..
I would connect that to port 3 of my rc210 controler that I have for my 2 M and 70 cm repeater’s.
If possible, how to i build the thing??
I know a few thing about Linux but I am no way a guru.. I do prefer a windows machine, but I know that Linux in more stable..
So is it possible or am I dreaming?
forgot to tell you that there is a serial and printerl port to the machine
you can see the spec there:
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c01571963/c01571963.pdf
Pierre
VE2PF
_______________________________________________ App_rpt-users mailing list App_rpt-users@ohnosec.org [http://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users](http://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users)
_______________________________________________ App_rpt-users mailing list App_rpt-users@ohnosec.org http://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users
Randy Hammock
Phone: 818-925-4576
_______________________________________________ App_rpt-users mailing list App_rpt-users@ohnosec.org ohnosec.org
