This has been going on for a while…on two of my sites. Some of the nodes show as active in the bubble chart…others are tinted pink.
For instance, at the present time, I’m showing all three of my nodes here as registered:
Host                  dnsmgr  Username               Perceived             Refresh  State
192.83.199.4:4569     Y       42761                  XX.XX.XX.XX:4569           60  Registered
216.244.83.154:4569   Y       28254                  XX.XX.XX.XX:4569           60  Registered
192.83.199.4:4569     Y       27710                  XX.XX.XX.XX:4569           60
Registered
But when I do a status check on, say, 27710 at the URL:
http://stats.allstarlink.org/getstatus.cgi?27710
It returns:
NODE INFO NOT FOUND!
I am seeing in my /var/log/asterisk/messages:
[May 20 11:00:11] ERROR[1481] app_rpt.c: event exec item malformed: /usr/bin/wget,-q,–timeout=15,–tries=1,–output-document=/dev/null
[May 20 11:00:11] ERROR[1481] app_rpt.c: event exec item malformed: http://stats.allstarlink.org/uhandler.php
I’ve tried rem’ing out the 2 lines for the wget and uhandler to report and grabbing the same two lines from the nodes that ARE working, but still getting the same results (for 27710, and, as an aside, my node 27294, fwiw).
So, on the same cpu, running 2 nodes plus a hub, the hub (28254) and the second node (42761) are fine…but 27710 isn’t, using the same commands in the rpt.conf file from the same iP address and port.
Hmmm…and the same thing is happening on my first node I registered 10 years ago…and was fine until a little while ago.
Taking tin foil MAGA hat off…
Thoughts? Any insight? Wondering…
73 de wb0yle/w2fuv
Morrisville PA
Fall River MA
