I have a node that is behind a NAT router that has trouble registering. Not all the time - just sometimes... The following ports are forwarded in the router, 4569, 22. Yes, ssh access was changed to 22.
The node connects to other nodes that are in the 'phone book'. I can putty to the node just fine. What am I missing?
I had a similar issue when I set my node up. In my case I was behind a NAT device (Cisco Firewall) and although I had the proper ports forwarded to my server, I had forgotten to build the global pool for that particular NAT'd address. SSH and connect worked, but it was not registering correctly because connections were being accepted on one IP address and it was reporting back to the registration server using a different IP address.
I had problems with registration when NATed behind a MikroTik router. Sometimes it would register, sometimes not. Turned out the dst-nat port forwarding was configured wrong and was forwarding 4569 from all interfaces. Fix was to add the WAN interface to the in-interface.
I had a similar issue when I set my node up. In my case I was behind a NAT device (Cisco Firewall) and although I had the proper ports forwarded to my server, I had forgotten to build the global pool for that particular NAT’d address. SSH and connect worked, but it was not registering correctly because connections were being accepted on one IP address and it was reporting back to the registration server using a different IP address.
Not all the time - just sometimes… The following ports are forwarded
The node connects to other nodes that are in the ‘phone book’. I can
