Node is not reporting statistical data or is offline
Hello ,
I have node that is being difficult ,
i am using the allstar3-arm64-3.1.1.img and i did un comment the line statpost_url = http://stats.allstarlink.org/uhandler in the rpt.conf
and also verify the password in the manager.conf and the allmon3.ini are the same still wont connect
any ideas ?
Node # ?
Have you checked/compared the node password (sudo asl-menu, Node Settings, AllStar Node Setup Menu, Update node ###, Node password) with the nodes password from www.allstarlink.org, Portal, Node Settings, ... ?
You might also try our recently announced asl-node-auth-check tool :
asl-node-auth-check: New Tool for Authentication and Node Reachability Testing
yes i did verify the password and I will try the tool tonight thanks
Hello this is what i received from the tool there is one error
-----===== AllStarLink Node Authentication Check =====-----
Checking configuration:
Info: rpt.conf has configuration for: 622260
Info: /etc/asterisk/iax.conf contains no registration lines.
Info: /etc/asterisk/rpt_http_registrations.conf contains 1 registration line(s)
Info: Registrations present for configured node(s): 622260
Info: IP from https://conntest-east1.allstarlink.org/ip reports: 57.134.21.129
Info: IP from https://conntest-west1.allstarlink.org/ip reports: 57.134.21.129
Info: IP from https://conntest-west2.allstarlink.org/ip reports: 57.134.21.129
Info: IP from udp://conntest-east1.allstarlink.org:4570 reports: 57.134.21.129
Info: IP from udp://conntest-west1.allstarlink.org:4569 reports: 57.134.21.129
Info: IP from udp://conntest-west2.allstarlink.org:4569 reports: 57.134.21.129
OK: HTTP IP probes have consensus on the same perceived IP
OK: IAX IP probes have consensus on the same perceived IP
Testing node 622260:
OK: Node registration config is well-formed
OK: Node registration type is HTTP
OK: register.allstarlink.org is reachable (via HTTP)
Error: HTTP registration state is Not Registered
Info: Stopping node checks due to registration failure
Info: as further information will be unreliable
 Error: Node 622260 has 1 error(s)!
root@VA2RTE:/etc/asterisk#
Are you certain that you have the correct node number and node password correct? You would get both of these from www.allstarlink.org. You would login to the site, click on "Portal", and then click on "Node Settings". Then, you can either select the "Show" button for the node to view the password or you can click the node link to view/edit the node settings (including the password).
Note: the node password is case sensitive (i.e. lowercase/uppercase matters).
Yup, you where correct i was missing a digit now it all works perfectly i verified everything except to compare with the website
thanks for your help
