Asl-node-auth-check: New Tool for Authentication and Node Reachability Testing
With the release of the package asl3-3.13, a new tool is available for testing configurations of ASL3 nodes. That tool is asl-node-auth-check. Once upgrading to the latest ASL3 code, this tool is available. I need to still add it to the manual.
The script does the following:
Overall Configuration
  • Checks the holistic configuration of Asterisk for what nodes are configure
  • Detects conflicts and mis-match between those configurations
  • Performs IP identity tests using both HTTP and IAX against three geographically and network-diverse locations to determine if there is a network issue involved such as CGNAT.
For each individual node
  • Checks that the registration configuration is well-formed and syntactically valid
  • Checks that a register.allstarlink.org host is reachable
  • Checks the registration status of the node
  • Validates that the IAX port defined in the configuration matches the database configuration
  • Checks that registration is current (i.e. one registration in the last 10 minutes)
  • Provides information on the last time the perceived IP changed
  • Uses the new Parrot/Reachability system to perform an inbound IAX reachabilty test
  • Provide a round-trip latency check
We hope this new tool will go a long way to debug configuration, registration, and network issues. Here is an example output of the tool:
# asl-node-auth-check
-----===== AllStarLink Node Authentication Check =====-----
Checking configuration:
      Info: rpt.conf has configuration for: 2001, 2000
      Info: /etc/asterisk/iax.conf contains no registration lines.
      Info: /etc/asterisk/rpt_http_registrations.conf contains 2 registration line(s)
      Info: Registrations present for configured node(s): 2000, 2001
      Info: IP from https://conntest-east1.allstarlink.org/ip reports: 18.224.69.177
      Info: IP from https://conntest-west1.allstarlink.org/ip reports: 18.224.69.177
      Info: IP from https://conntest-west2.allstarlink.org/ip reports: 18.224.69.177
      Info: IP from udp://conntest-east1.allstarlink.org:4570 reports: 18.224.69.177
      Info: IP from udp://conntest-west1.allstarlink.org:4569 reports: 18.224.69.177
      Info: IP from udp://conntest-west2.allstarlink.org:4569 reports: 18.224.69.177
        OK: HTTP IP probes have consensus on the same perceived IP
        OK: IAX IP probes have consensus on the same perceived IP
Testing node 2000:
        OK: Node registration config is well-formed
        OK: Node registration type is HTTP
        OK: register.allstarlink.org is reachable (via HTTP)
        OK: HTTP registration state is Registered
        OK: Perceived IAX IP:PORT for this node is: 18.224.69.177:4569
        OK: Registered to aws-east1a-register2.allstarlink.org - 52.44.147.201
        OK: Server-set UDP port matches bindport in iax.conf
        OK: Node registration within 10 minutes: 2026-02-14 20:53:50 UTC
      Info: Last time IP changed was 2025-11-24 02:43:17 UTC
        OK: Incoming connections to IAX from other nodes is successful
      Info: IAX ping test has a roundtrip time of 11ms
        OK: No problems detected with node 2000
Testing node 2001:
        OK: Registered to aws-east1a-register1.allstarlink.org - 52.21.169.197
        OK: Node registration within 10 minutes: 2026-02-14 20:53:53 UTC
      Info: Last time IP changed was 2025-11-24 02:53:07 UTC
      Info: IAX ping test has a roundtrip time of 12ms
        OK: No problems detected with node 2001
Greetings:
This works great on every Trixie install I’ve tried it on, but I get errors on a Bookworm install.
$ sudo asl-node-auth-check
Info: rpt.conf has configuration for: 592140, 592141, 1976
Traceback (most recent call last):
File "/usr/bin/asl-node-auth-check", line 679, in
main()
File "/usr/bin/asl-node-auth-check", line 588, in main
registrations = (get_registrations())
File "/usr/bin/asl-node-auth-check", line 126, in get_registrations
r = extract_registration_values(filename, regtype)
File "/usr/bin/asl-node-auth-check", line 107, in extract_registration_values
regtuple = regtuple + (regtype,)
TypeError: unsupported operand type(s) for +: 'NoneType' and 'tuple'
OS Kernel : 6.1.0-43-amd64
Asterisk : 22.7.0+asl3-3.7.1-1.deb12
ASL [app_rpt] : 3.7.1
Installed ASL packages :
Package Version
asl3 3.13-1.deb12
asl3-asterisk 2:22.7.0+asl3-3.7.1-1.deb12
asl3-asterisk-config 2:22.7.0+asl3-3.7.1-1.deb12
asl3-asterisk-modules 2:22.7.0+asl3-3.7.1-1.deb12
asl3-menu 1.16-1.deb12 asl3-update-nodelist 2.0.0-1.deb12
asl-apt-repos 2.0-1.deb12
dahdi 1:3.1.0-2
dahdi-dkms 1:3.4.0-10.asl.deb12
dahdi-linux 1:3.4.0-10.asl.deb12
dahdi-source 1:3.4.0-10.asl.deb12
Python version is 3.11.2.
Did your other systems have a private sub-2000 node configured? I think that's what it's choking on. I should probably ignore private nodes with the tool.
Can you try this and see if it resolves your problem: https://repo.allstarlink.org/hotfix/asl-node-auth-check
Oh, one other thing it could be, do you have your register stanzas using = or =>. The tool currently only supports the latter but probably I need to fix that too.
No, the other systems I tried it on didn’t have any private node configured.
No, it does not. Same result as before, running sudo ./asl-node-auth-check from my home directory.
Both existing registration lines were created by asl-menu, and they are ``register =>``
Can you PM me your iax.conf file?
More on this:
I just tried running asl-node-auth-check on a system behind CG-NAT, which I normally run behind a Tailscale exit node. For this test, I ran asl-node-auth-check first straight, then behind the VPN.
Without, It bombed out on the ping test. Worked fine on the VPN. Also, the last date of IP change is definitely wrong. Not sure how often it updates.
Here is the log.
root@pt-shari:/home/asl# asl-node-auth-check
Info: rpt.conf has configuration for: 508422
Info: /etc/asterisk/rpt_http_registrations.conf contains 1 registration line(s)
Info: Registrations present for configured node(s): 508422
Info: IP from https://conntest-east1.allstarlink.org/ip reports: 74.124.178.153
Info: IP from https://conntest-west1.allstarlink.org/ip reports: 74.124.178.153
Info: IP from https://conntest-west2.allstarlink.org/ip reports: 74.124.178.153
Info: IP from udp://conntest-east1.allstarlink.org:4570 reports: 74.124.178.153
Info: IP from udp://conntest-west1.allstarlink.org:4569 reports: 74.124.178.153
Info: IP from udp://conntest-west2.allstarlink.org:4569 reports: 74.124.178.153
Testing node 508422:
OK: Perceived IAX IP:PORT for this node is: 74.124.178.153:4568
OK: Registered to aws-east1a-register0.allstarlink.org - 52.20.63.146
OK: Node registration within 10 minutes: 2026-02-17 03:54:17 UTC
Info: Last time IP changed was 2026-02-07 04:44:35 UTC
main()
File "/usr/bin/asl-node-auth-check", line 658, in main
e, r = check_node_reachability(node)
File "/usr/bin/asl-node-auth-check", line 429, in check_node_reachability
pingms = node_check['ipv4']['pingms']
KeyError: 'pingms'
root@pt-shari:/home/asl# tailscale up
root@pt-shari:/home/asl# systemctl restart asterisk
Info: IP from https://conntest-east1.allstarlink.org/ip reports: 45.56.100.84
Info: IP from https://conntest-west1.allstarlink.org/ip reports: 45.56.100.84
Info: IP from https://conntest-west2.allstarlink.org/ip reports: 45.56.100.84
Info: IP from udp://conntest-east1.allstarlink.org:4570 reports: 45.56.100.84
Info: IP from udp://conntest-west1.allstarlink.org:4569 reports: 45.56.100.84
Info: IP from udp://conntest-west2.allstarlink.org:4569 reports: 45.56.100.84
OK: Perceived IAX IP:PORT for this node is: 45.56.100.84:4568
OK: Node registration within 10 minutes: 2026-02-17 03:57:28 UTC
Info: IAX ping test has a roundtrip time of 37ms
OK: No problems detected with node 508422
That's odd it's crashing there. With tailscale down, will you please run:
 wget -q -O- https://nodeping.allstarlink.org?node=508422
and paste the output in here.
{"calleraddr":"127.0.0.1","ipv4":{"rc":-9,"status":"unreachable"},"version":"20260128.1"}
That's very odd..... Thanks. I'll have to contemplate how to deal with that response in the code. That isn't one I encoutnered in testing.
Try the latest version I put up at that hotfix URL.
Not sure if this helps as this thread is 4wks old but I had occasion to use this cool new script today on a working Bookworm ASL3 node with the following result. Note that this node uses IAX2 vs HTTP registration as it was originally working through a T-mobile CGNAT connection but is now running over a 44 Connect wireguard VPN through a travel router. I also tried the version from the hotfix link in this thread with the same result except the traceback line numbers changed (ie 681→682 & 654→655). Hope it helps.
Info: Skipping evaluation of private node 1999
Info: rpt.conf has configuration for: 65418
Info: /etc/asterisk/iax.conf contains 1 registration line(s)
Info: /etc/asterisk/rpt_http_registrations.conf contains no registration lines.
Info: Registrations present for configured node(s): 65418
Warning: IP test to https://conntest-east1.allstarlink.org/ip failed
Info: IP from https://conntest-west1.allstarlink.org/ip reports: 44.27.135.61
Info: IP from https://conntest-west2.allstarlink.org/ip reports: 44.27.135.61
Warning: IP test to udp://conntest-east1.allstarlink.org:4570 failed
Info: IP from udp://conntest-west1.allstarlink.org:4569 reports: 44.27.135.61
Info: IP from udp://conntest-west2.allstarlink.org:4569 reports: 44.27.135.61
Testing node 65418:
OK: Node registration type is IAX
OK: IAX registration state is Registered
OK: Perceived IAX IP:PORT for this node is: 172.56.36.200:1120
File "/usr/bin/asl-node-auth-check", line 681, in
main()
File "/usr/bin/asl-node-auth-check", line 654, in main
e, r = check_node_status(node)
File "/usr/bin/asl-node-auth-check", line 383, in check_node_status
stats_udpport = stats['stats']['user_node']['server']['udpport']
TypeError: 'NoneType' object is not subscriptable
