Node 433260 connects OUT but refuses connections IN
Hello Community,
I having a strange problem with one of my nodes. It refuses to accept connections from other nodes, however, if I initiate a connection TO another node it works.
Example:
433260 >>>>>>>> 431420 - CONNECTION ESTABLISH
431420 >>>>>>>> 433260 - CONNECTION FAILED
431420 >>>>>>>>xxxxxxN - CONNECTION ESTABLISH - TO ALL OTHER NODES TESTED
Here is the CLI Warning:
== Manager ‘admin’ logged off from 127.0.0.1
– Accepting UNAUTHENTICATED call from 127.0.0.1:
> requested format = gsm,
> requested prefs = (gsm|ulaw|adpcm|g722|g726aal2|ilbc),
> actual format = ulaw,
> host prefs = (ulaw|adpcm|g722|g726aal2|gsm|ilbc),
> priority = mine
– Call accepted by 127.0.0.1 (format ulaw)
– Format for call is ulaw
– Executing [433260@radio-secure:1] Rpt(“IAX2/127.0.0.1:4569-15262”, “433260”) in new stack
[Jul 1 23:31:42] WARNING[1583]: app_rpt.c:22930 rpt_exec: Node 431420 IP 149.28.232.105 does not match link IP 127.0.0.1!!
== Spawn extension (radio-secure, 433260, 1) exited non-zero on ‘IAX2/127.0.0.1:4569-15262’
– Hungup ‘IAX2/127.0.0.1:4569-15262’
– Hungup ‘IAX2/127.0.0.1:4569-6454’
– Hungup ‘DAHDI/pseudo-1630450430’
– Hungup ‘DAHDI/pseudo-841527757’
– <DAHDI/pseudo-784443050> Playing ‘rpt/node’ (language ‘en’)
– <DAHDI/pseudo-784443050> Playing ‘digits/4’ (language ‘en’)
– <DAHDI/pseudo-784443050> Playing ‘digits/3’ (language ‘en’)
– <DAHDI/pseudo-784443050> Playing ‘digits/2’ (language ‘en’)
– <DAHDI/pseudo-784443050> Playing ‘digits/6’ (language ‘en’)
– <DAHDI/pseudo-784443050> Playing ‘digits/0’ (language ‘en’)
– <DAHDI/pseudo-784443050> Playing ‘rpt/connection_failed’ (language ‘en’)
THE KICKER
431420 resides on the same virtual server as 433260.
The iax, extentions, usbradio and rpt config scripts for 431420 are all edits of 433260. That is to say the required stantza for 431420 were copied, pasted and edited from 433260. Yet 431420 WORKS perfectly and 433260 REFUSES CONNECTIONS.
Looking forward to your kind assistance.
I was able to connect to both nodes.
Rick
Thanks for checking. I really do not understand why 432660 is not accepting any of my connections; However, if you can connect to it - that makes me happy. I will wait to see if anyone else presents a possible solution…
Thanks a million
Paul
See if this helps
https://wiki.allstarlink.org/wiki/Two_Nodes_on_One_Server
Hello wd6awp,
Firstly, thank you very much for taking the time to respond.
That is the very document I used to create the additional nodes. All of the additional nodes, 431420 and 431421 are working perfectly. What bothers me is that I started off the 433260 as the primary node. Then I followed the instructions you just guided me to create the others. The only difference (notwithstanding the obvious configurations) is that 433260 has echolink enabled.
Thanks a million for the tip and I truly appreciate the help.
I keep at it.
K9PSL
You say 431420 resides on the same virtual server as 433260.
Since both Nodes are on the same server …
In rpt.conf try adding each Node’s info using the server’s LAN IP not
12.0.0.1 to the stanza for opposite NODE’s stanza.
Like so
431420 = [email protected]:4569/431420,NONE
433260 = [email protected]:4569/433260,NONE
Then restart Asterisk
Larry - N7FM
On 7/2/20 8:23 AM, Paul Lowman (K9PSL) via AllStarLink Discussion Groups wrote:
[k9psl] k9psl https://community.allstarlink.org/u/k9psl
July 2
Hello wd6awp,
I keep at it.
K9PSL
Visit Topic
https://community.allstarlink.org/t/node-433260-connects-out-but-refuses-connections-in/17240/6
or reply to this email to respond.
    In Reply To
[wd6awp] wd6awp https://community.allstarlink.org/u/wd6awp ASL Admin
July 2
See if this helps Two Nodes on One Server - AllStarLink Wiki
    Previous Replies
July 2
See if this helps
July 2
possible solution…
Thanks a million
Paul
[KR8T] KR8T https://community.allstarlink.org/u/kr8t
July 2
Rick
July 2
Hello Community,
Example:
priority = mine
THE KICKER
Visit Topic
To unsubscribe from these emails, click here
https://community.allstarlink.org/email/unsubscribe/dc361543516b75444e9ae47c1d57f119200a5820a5b37bdded51d3c84fb043d3.
Hello k9psl,
Echolink is unlikely to be the problem. You can always rename or move the echolink.conf file to test. Also, if you can have someone put another set of eyes on your configs that might help. I’m guessing there is a small mistake there somewhere.
Hello Larry,
PROBLEM SOLVED!!!
I have been pulling at my scalp about his for a few weeks now because I wanted to be sure that I did all I could before coming to the forum. A million ‘thank you’ for the tip, 433260 now functions perfectly.
I can connect IN and OUT with each of the nodes.
All the best!
Paul
Hello Tim,
Once again thanks for pointing me in the right direction. I was about to tear down the Echolink portion of 433260, but I attempted Larry’s fix and that worked. A suggestion to perhaps add the text of this fix as an amendment to the documentation on the Wiki just in case others encounter the same problem. I think Larry contextualized it best, so here is a quick cut and paste if you concur:
PROPOSED AMENDMENT BEGINS****
If you experience connection problems among your nodes residing on the same server, in rpt.conf try using the server’s LAN IP instead of the default 127.0.0.1 for each NODE stanza configuration:
For example:
XXX420 = [email protected]:4569/XXX420,NONE
433XXX = [email protected]:4569/433XXX,NONE
PROPOSED AMENDMENT ENDS****
Again,
I really appreciate the help and I hope I can be of help to others in the future.
K9PSL
Paul
Glad you got it working Paul…
Larry - N7FM
On 7/2/20 9:56 PM, Paul Lowman (K9PSL) via AllStarLink Discussion Groups wrote:
July 3
Hello Larry,
PROBLEM SOLVED!!!
All the best!
Paul
Visit Topic
https://community.allstarlink.org/t/node-433260-connects-out-but-refuses-connections-in/17240/9
    In Reply To
[larry] larry https://community.allstarlink.org/u/larry
July 2
You say 431420 resides on the same virtual server as 433260. Since both
Nodes are on the same server … In rpt.conf try adding each Node’s info
using the server’s LAN IP not 12.0.0.1 to the stanza for opposite NODE’s
stanza. Like so 431420 = [email protected]:4569/431420,NONE 433260 =
radio@19…
    Previous Replies
July 3
Hello k9psl,
July 2
Like so
Larry - N7FM
··· (click for more details)
https://community.allstarlink.org/t/node-433260-connects-out-but-refuses-connections-in/17240/7
July 2
Hello wd6awp,
I keep at it.
K9PSL
July 2
See if this helps
July 2
possible solution…
Thanks a million
Paul
Visit Topic
https://community.allstarlink.org/email/unsubscribe/576807865db34c42b8c125ef562b8ab2055e02c1955c59c25e7a4229963b2993.
