NNX beta testing is open now through the planned release date of 7/1/19.
To participate in the beta you must have an AllStar account and a working node which you are willing to modify per these instructions .
Please reply to this post or send me a PM with your callsign to get started.
Beta testers will see NNX Beta Test on the Portal Menu. It may be necessary to logout and back in to have the Beta Test menu item appear.
Hi am am interested in becoming a Beta testers for NNX Beta Test on the Portal Menu.
Regards
Mark Harris VK3EME
node 44099
ea8ee
May 26, 2019, 9:37am
3
I Would like to become betatester
@VK3EME Ok, you’re all set. Let us know how it goes.
@ea8ee you’re all set. Keep us posted.
I have added nnx to the Node List node column. Filter won’t find nnx (or wt), you have to use the Node column search box.
VK3EME
May 27, 2019, 11:44am
7
Sorry goofed up a bit doing it and accidentally requested 2 new node numbers by mistake. Will I be able to delete them later.
Regards
VK3EME
On Mon, 27 May 2019 at 00:38, Tim Sawyer via AllStarLink Discussion Groups [email protected] wrote:
wd6awp
ASL Admin
May 26
In Reply To
VK3EME
May 26
Hi am am interested in becoming a Beta testers for NNX Beta Test on the Portal Menu. Regards Mark Harris VK3EME node 44099
To unsubscribe from these emails, click here .
Yes, you should be able to delete them later.
@ea8ee @VK3EME , How goes the beta testing? Have any questions?
VK3EME
June 2, 2019, 3:04am
10
Great thing, as able to create consecutive nodes and able to change them back with out a problem. I haven’t tried to shift nodes created this way to different servers yet as been a bit busy work wise.
But a great job done on creating the ability to do these things.
Regards
Mark Harris
VK3EME / VK3OU
On Fri, 31 May 2019 at 01:32, Tim Sawyer via AllStarLink Discussion Groups [email protected] wrote:
wd6awp
ASL Admin
May 30
In Reply To
wd6awp
ASL Admin
May 27
