k4sip
1
Hello all,
The Live Keyed Nodes (Beta) page is providing blank output.
When I run debug console on the page output (f12->console), I’m seeing an error that might explain why – but I’m not sure.
http://stats.allstarlink.org/stats/keyedBeta
Uncaught You must pass your app key when you instantiate Pusher.
Byron
WD6AWP
3
I’ll see what’s up with that.
VA4SMC
4
Hi Byron, have you heard of any updates about this issue? I am seeing the same.
Scott
It is blank for me too. Do I need a different browser? Chrome here.
WD6AWP
6
It’s not you. The AllStarLink Keyed Nodes (Beta) is still down. I see the map is not working either.
Since November? Who’s in charge here!
iOS apps that use the map API also fail.
VA4SMC
9
It appears the administration has turned this feature off because of high use of resources.
