iaxRpt HELP TAKE 2
Having come back from the dark room I have been sitting in for days letting my hair grow!
Time to have another go with ASL3 getting iaxRpt Windows APP to work.
Does anyone have time to respond with an IDIOTS Guide of what to do.
I have two of my three nodes working with iaxRpt and ASL2.
Yes iaxRpt is old and doesn’t support tokens but I have a specific need with my DATV station via QO100 satellite.
There seems to be stations posting that it is working for them.
My LINUX knowledge is limited and my age is against me which is why I need an IDIOTS Guide.
Hope someone can help! or will have to go back into my dark room.
Martin
G8KOE
Have you seen this?
This is all it took for me.
I have used it over a decade and added the requirecalltoken = no for asl3
iax.conf
[iaxrpt]
type = user
context = iaxrpt
auth = md5
secret = secret
host = dynamic
disallow = all
allow = ulaw
;allow = adpcm
allow = gsm
transfer = no
extentions.conf
[iaxrpt]
exten => 48233,1,rpt(48233|X)
exten => 48234,1,rpt(48234|X)
Note: I do not use the var global logic for this.
I have to many private nodes to track and see no use for it. I like exact definition.
But if you use the stock stanza, you need to fill in a global var for node = xxxxx at the top of extentions.conf. Create a new one for a second node of a different variable name and add that to the stanza.
in iaxrpt program
Make sure your user = iaxrpt
“Account Name” becomes node#.
Don’t confuse this with “user”, which is the stanza name.
Anyway, that should clear up where I think many are in error.
EDIT:
For a followup
Do not describe a "username=" for your personal admin control stanza
(iaxrpt / iax.conf).
Use that for iax-clients you may give access to your system on a individual bases.
It is required in the iaxclient stanza.
And those are type ‘friend’ and not ‘user’. See the iaxclient stanza as you will match username and password for security.
This changes the security for access.
For clients connect as mode “P” - phone mode. Not “X”
iaxrpt connects using “X” will not be directly visible to you on allmon/supermon.
They are for admin use and transparent.
Take a peek at both the stanzas in extensions.conf and I think you will understand.
iax-clients will also require “requirecalltoken = no” in that stanza
You can always limit users with any number of IP/range limitations
permit=192.168.1.0/24
permit=75.150.0.0/16
permit=25.80.119.57
in the same stanza for additional security with some flexibility.
And I might even suggest that ‘where possible’ in the iaxrpt stanza.
But make it work first before adding any extra security.
I would also advise to comment out either of these stanza’s if you are not using them,
or at least change the default secret to something new and long.
I may post an example “iax client” stanza and iaxrpt setup for it when I have time.
But I think I have given the framework to understand iaxclients as well.
Mike,
Thankyou for taking the time to explaine.
Made my settings to corispond with yours.
Hit the connect button in iaxRpt app and to my surprise got the OK connected.To Node.
Now all working thanks to you.
Martin
Thanks Martin,
I made a few adjustments in the WIKI ‘howto’ to explain it as well for ASL3.
Hopefully that will do it.
Is it possible to make it a private node for the IAX Clients?
I also noticed that when I connect, it doesn’t say the node number or that it is connected.
Thank you
Create a private node and make a dialplan path to it in extensions.conf
If the connection with iaxrpt is connecting in mode X
you will not have any notification of the connection and not exactly what we call a IAX-Cient, but a administrative connection.
Look at the iax-client example in your files, it is different.
I have created a private node, but this has me lost, make a dialplan path to it in the extensions.conf? I don’t know what you mean, sorry
this? exten => 1775,1,rpt(1775|X)
this is what I show, but unless my sight is off, I don’t show a difference between them.
[iaxrpt] ; Connect from iaxrpt Username field (PC AllStar Client)
type = user ; Notice type is user here <---------------
context = iaxrpt ; Context to jump to in extensions.conf
auth = md5
secret = Passw0rd
disallow = all
allow = ulaw
allow = adpcm
allow = gsm
transfer = no
requirecalltoken=no
[iaxclient] ; Connect from iax client (Zoiper…)
type = friend ; Notice type here is friend <--------------
context = iax-client ; Context to jump to in extensions.conf
auth = md5
secret = Passw0rd
host = dynamic
disallow = all
allow = ulaw
allow = adpcm
allow = gsm
transfer = no
requirecalltoken=no
Yes, extensions.conf in the correct context that will be calling it.
iaxrpt is connecting as ‘user’
iaxclient is connecting as freind
The difference is the protocol used and how security is handled.
If you are trying to make a iaxclient the node, well good luck.
You will have to connect to it instead.
Although you might be able to give that as an appearance, not worth it.
Hope that helps some.
