And below is the extensions.conf file content:-
; WARNING - THIS FILE WAS AUTOMATICALLY CONFIGURED FROM A
; TEMPLATE FILE IN /usr/local/etc/asterisk_tpl BY THE
; NODE-CONFIG.SH SCRIPT.
; EACH TIME THIS SCRIPT IS RUN, THIS FILE WILL BE OVERWRITTEN.
; IF YOU CHANGE ANYTHING IN THIS FILE AND RUN THE NODE-CONFIG.SH
; SCRIPT, IT WILL BE LOST.
; IF YOU INTEND TO USE THE NODE-CONFIG.SH SCRIPT, THEN YOU SHOULD
; MAKE MODIFICATIONS TO THE ACTUAL TEMPLATE FILES LOCATED IN
; /usr/local/etc/asterisk_tpl directory.
; Shown for two nodes, second node commented out.
; change ALL 53047 and 1999 (if second node used) to
; your local node numbers
; Updated 1/2019 to include additional features
; Before attempting to add features ensure they
; are not already installed
[general]
static=yes ; These two lines prevent the command-line interface
writeprotect=yes ; from overwriting the config file. Leave them here.
[globals]
HOMENPA=215
[default]
exten => i,1,Hangup
[radio-secure]
exten => 53047,1,rpt,53047
exten => 1999,1,rpt,1999
[radio-secure-proxy]
exten => 53047,1,rpt,53047|X
exten => _0X.,1,Goto(allstar-sys|${EXTEN:1}|1)
; IAXRPT Windows
[radio-iaxrpt]
exten=53047,1,Rpt,53047|X
exten => 53047,1,Answer
exten => 53047,n,Playback,rpt/node
exten => 53047,n,Playback,digits/5
exten => 53047,n,Playback,digits/3
exten => 53047,n,Playback,digits/0
exten => 53047,n,Playback,digits/4
exten => 53047,n,Playback,digits/7
exten => 53047,n,Set(CALLERID(num)=0)
exten => 53047,n,Rpt,53047|P|${CALLERID(name)} ;;; The “CallerID” from IAXRpt
; The following stanza is to be used for Android/Iphone
; connections. Please configure the node number for the
; node on this server you want to connect to.
; The callerID name is configured and returned from
; your phone. It is typically your call.
[phone-iaxrpt] ;;; Stanza is the context from iax.conf
; To make this have a static callerID name if your phone
; app does not support callerID change the last line to this
; and specify the name (usually CALL) in place of static-name.
;exten => 53047,n,Rpt,1998|P|“static-name”
; Autopatch example lines. Must be configured and
; SIP or IAX phone connections configured to work.
[pstn-out]
exten=_NXXNXXXXXX,1,playback(ss-noservice)
exten=_NXXNXXXXXX,2,Congestion
[invalidnum]
exten=s,1,Wait,3
exten=s,n,Playback,ss-noservice
exten=s,n,Wait,1
exten=s,n,Hangup
[radio]
exten=_X11,1,Goto(check_route|${EXTEN}|1);
exten=_NXXXXXX,1,Goto(check_route|1${HOMENPA}${EXTEN}|1)
exten=_1XXXXXXXXXX,1,Goto(check_route|${EXTEN}|1)
[check_route]
; no 800
exten=_1800NXXXXXX,2,Goto(invalidnum|s|1)
exten=_1888NXXXXXX,2,Goto(invalidnum|s|1)
exten=_1877NXXXXXX,2,Goto(invalidnum|s|1)
exten=_1866NXXXXXX,2,Goto(invalidnum|s|1)
exten=_1855NXXXXXX,2,Goto(invalidnum|s|1)
; no X00 NPA
exten=_1X00XXXXXXX,2,Goto(invalidnum|s|1)
; no X11 NPA
exten=_1X11XXXXXXX,2,Goto(invalidnum|s|1)
; no X11
exten=_X11,2,Goto(invalidnum|s|1)
; no 555 Prefix in any NPA
exten=_1NXX555XXXX,2,Goto(invalidnum|s|1)
; no 976 Prefix in any NPA
exten=_1NXX976XXXX,2,Goto(invalidnum|s|1)
; no NPA=809
exten=_1809XXXXXXX,2,Goto(invalidnum|s|1)
; no NPA=900
exten=_1900XXXXXXX,2,Goto(invalidnum|s|1)
; okay, route it
exten=_1NXXXXXXXXX,1,Goto(pstn-out|${EXTEN:1}|1)
exten=_X.,2,Goto(invalidnum|s|1)
; End autopatch example
; Following stanza required for web transceiver access
[allstar-public]
exten => s,1,Ringing
exten => s,n,Set(RESP=${CURL(https://register.allstarlink.org/cgi-bin/authwebphone.pl?${CALLERID(name)})})
exten => s,n,Set(NODENUM=${CALLERID(number)})
exten => s,n,GotoIf($["${RESP:0:1}" = “?”]?hangit)
exten => s,n,GotoIf($["${RESP:0:1}" = “”]?hangit)
exten => s,n,GotoIf($["${RESP:0:5}" != “OHYES”]?hangit)
exten => s,n,Set(CALLSIGN=${RESP:5})
exten => s,n,Wait(3)
exten => s,n,Playback(rpt/node|noanswer)
exten => s,n,Saydigits(${NODENUM})
exten => s,n,Set(CALLERID(num)=0)
exten => s,n,Set(CALLERID(name)=${CALLSIGN})
exten => s,n,Rpt(${NODENUM}|X)
exten => s,n,Hangup
exten => s,n(hangit),Answer
exten => s,n(hangit),Wait(1)
exten => s,n(hangit),Hangup
exten => 9999,1,Goto(allstar-public|s|1)
; end web transceiver stanza
; Following stanza required for phone access
[allstar-sys]
exten => _x.,1,Ringing
exten => _x.,n,Wait(3)
exten => _x.,n,Answer
exten => _x.,n,Playback(rpt/node)
exten => _x.,n,Saydigits(${EXTEN:1})
exten => _x.,n,Rpt(${EXTEN:1}|P|${CALLERID(name)}-P)
exten => _x.,n,Hangup
; end phone access stanza
; The blacklist and whitelist stanzas below are used to allow or ban nodes
; from connecting. Only one can be selected at a time as defined in the
; [radio] stanza of iax.conf
; The best way to allow or ban nodes from the database is to
; use the Supermon application or the node-ban-allow.sh script.
; No changes need to be made to these stanzas. See comments in iax.conf.
[blacklist]
exten => _XXXX!,1,NoOp(${CALLERID(num)})
exten => _XXXX!,n,GotoIf($[${DB_EXISTS(blacklist/${CALLERID(num)})}]?blocked)
exten => _XXXX!,n,Goto(radio-secure,${EXTEN},1)
exten => _XXXX!,n(blocked),Hangup
[whitelist]
exten => _XXXX!,n,NoOp(${IAXPEER(CURRENTCHANNEL)})
exten => _XXXX!,n,GotoIf($["${IAXPEER(CURRENTCHANNEL)}" = “127.0.0.1”]?radio-secure,${EXTEN},1) ;permit local IPs
exten => _XXXX!,n,GotoIf($[${DB_EXISTS(whitelist/${CALLERID(num)})}]?radio-secure,${EXTEN},1)
exten => _XXXX!,n,Hangup
; Stanza to get node number and pass to saydns.sh script in rpt.conf
[saydns]
exten => _xxx.,1,System(/usr/local/sbin/saydns.sh ${EXTEN})
exten => _xxx.,n,Hangup()
; Example connection to another Asterisk server
; and passing an extension
; [pbx_server]
;exten => _1NXXNXXXXXX,1,Dial(IAX2/pbx/${EXTEN})
;exten => _NXXNXXXXXX,1,Dial(IAX2/pbx/${EXTEN})
;exten => _NXX,1,Dial(IAX2/pbx/${EXTEN})
;exten => _NX,1,Dial(IAX2/pbx/${EXTEN})
#includeifexists custom/extensions.conf
