;lnkactenable = 0 ; Set to 1 to enable the link activity timer. Applicable to standard nodes only.
;lnkacttime = 1800 ; Link activity timer time in seconds.
;lnkactmacro = *52 ; Function to execute when link activity timer expires.
;lnkacttimerwarn = 30seconds ; Message to play when the link activity timer has 30 seconds left.
Are you using hamvoip software ?
the recent update in Dec-Jan has some problems, I have the cures but just want to know if you are using hamvoip or AllStarLink
The original remote base mode isn’t supported in HamVoIP, since no IAX2 link messages get sent when enabled as a “remote base.” HamVoIP requires link message (aka: heartbeats) at least every 45 seconds.
The simple solution is to just turn off the “remote base” mode by setting: “Is node a remote base station” to “No” in the allstarlink.org, “Node settings” section list.
I am having the same issue w/ 49562. I have forwarded the “remote base” setting comment to one of the local administrators associated with this node. Thanks for the good info!
David your expert advice solved the problem! I tested 49562 after they toggled their remote base setting and I was not disconnected. I hope this thread will help others in the future.
Thanks again!
Clifford
