First log in to Pi
Hello Group;
New user here.
I have just burnt the ASL image onto the SD card, loaded it into the Pi, and booted up - all as per instructions.
I try to log in to the Pi as “repeater” using the initial login password of “allstarlink” as found in the first time set-up instructions.
I then get “access denied”. I have tried multiple times, and done multiple image burns, to no avail.
Can anyone assist me to get past this stumbling block so I can get to the set up menu?
Many thanks - Tim.
VK3MIT
Tim,
What location are you downloading your image from?
Marshall
From: Timothy Mc Bain via AllStarLink Discussion Groups [mailto:[email protected]]
Sent: Wednesday, May 20, 2020 4:56 AM
To: [email protected]
Subject: [AllStarLink Discussion Groups] First log in to Pi
VK3MIT-Tim
May 20
Hello Group;
New user here.
Many thanks - Tim.
VK3MIT
Hi Marshall; sorry to be a pain…
The image is from the ASL web site - downloads fine, unzips fine, burns onto the SD fine, appears to run fine in the Pi, just won’t progress beyond login as repeater/access denied.
I can log in as root, and I get the auto update process happening, and end up at a root login prompt, but I can’t get to the ASL setup cli from root as it wants to be user repeater. It’ll try to switch user to repeater, but fails on the repeater default password.
Tim.
On 21 May 2020, at 04:03, Marshall Oldham via AllStarLink Discussion Groups [email protected] wrote:
KE6PCV
ASL Admin
    May 20
Tim,
Marshall
··· (click for more details)
In Reply To
VK3MIT-Tim
    May 20
Hello Group; New user here. I have just burnt the ASL image onto the SD card, loaded it into the Pi, and booted up - all as per instructions. I try to log in to the Pi as “repeater” using the initial login password of “allstarlink” as found in the first time set-up instructions. I then get “acce…
Tim,
Start over and try the following burning the image onto your mirco sd card again.
Then install the micro sd into the Pi and boot.
Do the following.
Login: repeater
Passsword: allstarlink
User repeater has sudo privileges (sudo -s)
Note: You really do not need to login at user ROOT or even setup with user ROOT.
There have been updates to the operating system since this image was built.
Run the following commands after the first time you boot.
sudo apt-mark hold raspberrypi-kernel-headers raspberrypi-kernel
sudo apt-get update
sudo apt-get upgrade -y
sudo reboot
at the # prompt run “asl-menu” to setup your node.
Read this on the wiki all the way to the end it has directions to walk you through setting up your node with screen shots.
https://wiki.allstarlink.org/wiki/Beginners_Guide
Marshall - ke6pcv
Sent: Wednesday, May 20, 2020 1:19 PM
VK3MIT-Tim
May 20
Tim.
In Reply To
KE6PCV ASL Admin
May 20
Tim, What location are you downloading your image from? Marshall ··· (click for more details)
Previous Replies
KE6PCV ASL Admin
May 20
Tim,
Marshall
VK3MIT-Tim
May 20
Hello Group;
New user here.
Many thanks - Tim.
VK3MIT
I downloaded Raslink-20.04
Win 10 machine, used “Etcher” to put the unzipped ISO onto the SD card.
T.
Tim.
KE6PCV
ASL Admin
    May 20
Tim,
Marshall
In Reply To
VK3MIT-Tim
    May 20
Tim,
I am not familiar with what Raslink is, it’s not an ASL image.
Go here to download the lastest ASL image for the Raspberry Pi.
http://dvswitch.org/files/ASL_Images/Raspberry_Pi/Stretch/
Use this image and you should be good to go if you follow the directions.
Marshall
Sent: Wednesday, May 20, 2020 3:00 PM
VK3MIT-Tim
May 20
T.
In Reply To
KE6PCV ASL Admin
May 20
Previous Replies
KE6PCV ASL Admin
May 20
Tim,
Do the following.
Login: repeater
sudo apt-get update
sudo reboot
Marshall - ke6pcv
VK3MIT-Tim
May 20
Tim.
KE6PCV ASL Admin
May 20
Tim,
Marshall
VK3MIT-Tim
May 20
Hello Group;
New user here.
Many thanks - Tim.
VK3MIT
