Mike,
Thanks for the reply. Here is what I have in the HamVoip RC.19
Rpt.conf
[1400] ; Change this to your assigned node number
; Channel Driver settings
; Define a channel driver to use and which
; interface within that channel driver
; To define a radioless node use the
; psuedo channel driver - rxchannel=dahdi/pseudo
rxchannel=Radio/usb1400
; Example usbradio channel driver
;rxchannel=SimpleUSB/usb
; Example simpleusb channel driver
;rxchannel=dahdi/pseudo
; Example pseudo channel driver
List of programs in asterisk
[root@1400_Home_Test asterisk]# ls
amd.conf indications.conf
asterisk.conf local
chan_dahdi.conf logger.conf
dnsmgr.conf manager.conf
dundi.conf modules.conf
echolink.xxx rpt.conf
extensions.conf rpt.conf.sample
extensions.conf_2018.12.30.2105 rpt.conf_2018.12.30.2105
extensions.conf_2018.12.30.2113 rpt.conf_2018.12.30.2113
extensions.conf_2018.12.30.2114 rpt.conf_2018.12.30.2114
extensions.conf_orig rpt.conf_orig
features.conf simpleusb.conf
iax.conf simpleusb.conf_2018.12.30.2113
iax.conf_2018.12.30.2105 simpleusb.conf_2018.12.30.2115
iax.conf_2018.12.30.2113 simpleusb_tune_usb.conf
iax.conf_2018.12.30.2114 sip.conf
iax.conf_orig usbradio.conf.xxx
usbradio.conf.xxx
; Usbradio channel driver Configuration File
[general]
[usb1400]
hdwtype=0
rxboost=1
txboost=1
rxctcssrelax=1
txctcssdefault=100.0
rxctcssfreqs=100.0
txctcssfreqs=100.0
;rxctcssoverride=0
carrierfrom=dsp
ctcssfrom=dsp
rxdemod=flat
txprelim=yes
txlimonly=no
txtoctype=notone
txmixa=composite
txmixb=0
invertptt=0
duplex=1
rxondelay=0
rxnoisefiltype=0
eeprom=0
#includeifexists custom/usbradio.conf
Modules.conf
; Asterisk configuration file
; Module Loader configuration file
[modules]
autoload=yes
;noload=chan_voter.so
;noload=chan_usbradio.so
;noload=chan_irlp.so
;noload=chan_echolink.so
;noload=chan_simpleusb.so
noload=app_hamvoip.so
;noload=res_crypto.so
;noload=func_callerid.so
noload=chan_oss.so
noload=chan_alsa.so
noload=chan_phone.so
noload=res_config_pgsql.so
noload=cdr_pgsql.so
noload=app_radbridge.so
noload=app_festival.so
noload=app_queue.so
noload=func_odbc.so
noload=chan_mgcp.so
noload=chan_skinny.so
noload=cdr_custom.so
noload=cdr_csv.so
noload=chan_agent.so
noload=chan_simple2.so
noload=func_moh.so
noload=res_musiconhold.so
noload=res_speech.so
noload=res_odbc.so
noload=res_smdi.so
noload=res_config_odbc.so
noload=chan_tlb.so
noload=app_milliwatt.so
noload=app_image.so
noload=app_sendtext.so
noload=format_h264.so
noload=app_hasnewvoicemail.so
noload=app_ices.so
noload=app_lookupblacklist.so
noload=app_voicemail.so
noload=chan_usrp.so
noload=app_lookupidname.so
noload=app_zapateller.so
noload=format_jpeg.so
noload=app_parkandannounce.so
noload=app_meetme.so
noload=app_settransfercapability.so
noload=app_amd.so
noload=app_followme.so
noload=app_transfer.so
noload=app_directed_pickup.so
noload=app_flash.so
noload=app_page.so
noload=app_gps.so
noload=pbx_dundi.so
noload=app_setcallerid.so
noload=app_dictate.so
noload=res_adsi.so
noload=app_mp3.so
noload=app_privacy.so
noload=app_disa.so
noload=app_alarmreceiver.so
noload=app_externalirv.so
noload=chan_beagle.so
noload=chan_sip.so
[global]
-----Original Message-----
From: App_rpt-users [mailto:[email protected]] On Behalf Of Mike
Sent: Tuesday, January 01, 2019 11:10 AM
To: [email protected]
Subject: Re: [App_rpt-users] CM119 USB interface
Mark,
Can you show me the line in your rpt.conf where you are loading the channel.
ie rxchannel = Radio/usb_29285
And your usbradio.conf file text
...mike/kb8jnm
What
On 1/1/2019 9:19 AM, Mark DuMoulin wrote:
Kevin,Brian;
I have been trying to set up use of radiousb instead of simpleusb. I see here Brian is doing that with the issues he is having.
I can't get nearly that far.
I am running hamvoip rc19 on some and recently downloaded stretch.
In both cases I set the usbradio module to load however I cannot get the driver to work and keep getting asterisk failures.
Additionally the menus set up by the programmer show only simpleusb-radio-tune not radio-tune-menu.
Is there another image or procedure I need to run to get this started?
Tnx,
Mark
WB2ERS
Kevin Custer
Sent: Monday, December 24, 2018 2:57 PM
To: Users of Asterisk app_rpt; Brian G
On 12/24/2018 12:21 AM, Brian G wrote:
Ok, I'm thick sometimes
I get what you're saying now, makes sense.
Thank you for the clarification. The Motorola is working as you
described, the other rigs not so much.
So the gist of it is, there's no way to use DSP carrier detect
without using discriminator audio? It's CTCSS or VOX only in that case?
Correct -
BUT, discriminator audio should be available from that M120 radio. You just have to hook it up and possibly program it correctly.
Kevin
[email protected]
[email protected]
[email protected]
[email protected]
