CM119 USB interface
Not to my knowledge.
You can have different - multiple tones defined for a single node. Sort of like a tone panel in commercial repeater systems, but I've never heard of using multiple node instances on one radio interface.
Kevin
On 1/2/2019 12:06 PM, Mark DuMoulin wrote:
Kevin,
Can different ctcss tones be associated with a single USBFOB identified and configured as a separate node?
I remember reading about different tone that triggered the event system in asterisk and made possible to have a local qso even if connected to other nodes…
Kevin,
of like a tone panel in commercial repeater systems, but I’ve never
Kevin
I believe that was a scheme to change the output links based on
PL input tone.
  So using one tone stayed local machine and some other went
through local and the network connects.
It’s probably still in the archives of the mail list.
I remember when the topic came up.
…mike/kb8jnm
On 1/2/2019 6:03 PM, Pierre Martel
Le mer. 2 janv. 2019 à 17:02, Kevin Custer <kuggie@kuggie.com >
a écrit :
      On
      > Kevin,
node. Sort
never
      Kevin
      [http://lists.allstarlink.org/cgi-bin/mailman/listinfo/app_rpt-users](http://lists.allstarlink.org/cgi-bin/mailman/listinfo/app_rpt-users)
      To unsubscribe from this list please visit [http://lists.allstarlink.org/cgi-bin/mailman/listinfo/app_rpt-users](http://lists.allstarlink.org/cgi-bin/mailman/listinfo/app_rpt-users)
      and scroll down to the bottom of the page. Enter your email
address and press the “Unsubscribe or edit options button”
email confirmation. If you have trouble unsubscribing, please
send a message to the list detailing the problem.
Kevin,
Understood. Do you have a config example of multiple tones for a single node?
Tnx,
Mark
-----Original Message-----
Sent: Wednesday, January 02, 2019 4:35 PM
To: Mark DuMoulin; Users of Asterisk app_rpt
Subject: Re: [App_rpt-users] CM119 USB interface
Kevin,
Kevin
You include the tones you want to decode - encode, separating them
with a comma, and define a default to start (or rest) at.
Example:
On 1/3/2019 1:47 PM, Mark DuMoulin
wrote:
txctcssdefault=151.4
rxctcssfreqs=146.2,141.3,151.4
txctcssfreqs=146.2,141.3,151.4
Kevin W3KKC
Kevin,
Mark,
Not sure if you got this working or not.
I believe the file usbradio.conf.xxx is just a templet. Rename it to usbradio.conf.
LaRoy McCann - K5TW
On 1/1/2019 11:26 AM, Mark DuMoulin wrote:
Mike,
Thanks for the reply. Here is what I have in the HamVoip RC.19
Rpt.conf
[1400] ; Change this to your assigned node number
; Channel Driver settings
                                 ; Define a channel driver to use and which
                                 ; interface within that channel driver
                                 ; To define a radioless node use the
                                 ; psuedo channel driver - rxchannel=dahdi/pseudo
rxchannel=Radio/usb1400
                                 ; Example usbradio channel driver
;rxchannel=SimpleUSB/usb
                                 ; Example simpleusb channel driver
;rxchannel=dahdi/pseudo
                                 ; Example pseudo channel driver
List of programs in asterisk
[root@1400_Home_Test asterisk]# ls
amd.conf indications.conf
asterisk.conf local
chan_dahdi.conf logger.conf
dnsmgr.conf manager.conf
dundi.conf modules.conf
echolink.xxx rpt.conf
extensions.conf rpt.conf.sample
extensions.conf_2018.12.30.2105 rpt.conf_2018.12.30.2105
extensions.conf_2018.12.30.2113 rpt.conf_2018.12.30.2113
extensions.conf_2018.12.30.2114 rpt.conf_2018.12.30.2114
extensions.conf_orig rpt.conf_orig
features.conf simpleusb.conf
iax.conf simpleusb.conf_2018.12.30.2113
iax.conf_2018.12.30.2105 simpleusb.conf_2018.12.30.2115
iax.conf_2018.12.30.2113 simpleusb_tune_usb.conf
iax.conf_2018.12.30.2114 sip.conf
iax.conf_orig usbradio.conf.xxx
usbradio.conf.xxx
; Usbradio channel driver Configuration File
[general]
[usb1400]
hdwtype=0
rxboost=1
txboost=1
rxctcssrelax=1
txctcssdefault=100.0
rxctcssfreqs=100.0
txctcssfreqs=100.0
;rxctcssoverride=0
carrierfrom=dsp
ctcssfrom=dsp
rxdemod=flat
txprelim=yes
txlimonly=no
txtoctype=notone
txmixa=composite
txmixb=0
invertptt=0
duplex=1
rxondelay=0
rxnoisefiltype=0
eeprom=0
#includeifexists custom/usbradio.conf
Modules.conf
; Asterisk configuration file
; Module Loader configuration file
[modules]
autoload=yes
;noload=chan_voter.so
;noload=chan_usbradio.so
;noload=chan_irlp.so
;noload=chan_echolink.so
;noload=chan_simpleusb.so
noload=app_hamvoip.so
;noload=res_crypto.so
;noload=func_callerid.so
noload=chan_oss.so
noload=chan_alsa.so
noload=chan_phone.so
noload=res_config_pgsql.so
noload=cdr_pgsql.so
noload=app_radbridge.so
noload=app_festival.so
noload=app_queue.so
noload=func_odbc.so
noload=chan_mgcp.so
noload=chan_skinny.so
noload=cdr_custom.so
noload=cdr_csv.so
noload=chan_agent.so
noload=chan_simple2.so
noload=func_moh.so
noload=res_musiconhold.so
noload=res_speech.so
noload=res_odbc.so
noload=res_smdi.so
noload=res_config_odbc.so
noload=chan_tlb.so
noload=app_milliwatt.so
noload=app_image.so
noload=app_sendtext.so
noload=format_h264.so
noload=app_hasnewvoicemail.so
noload=app_ices.so
noload=app_lookupblacklist.so
noload=app_voicemail.so
noload=chan_usrp.so
noload=app_lookupidname.so
noload=app_zapateller.so
noload=format_jpeg.so
noload=app_parkandannounce.so
noload=app_meetme.so
noload=app_settransfercapability.so
noload=app_amd.so
noload=app_followme.so
noload=app_transfer.so
noload=app_directed_pickup.so
noload=app_flash.so
noload=app_page.so
noload=app_gps.so
noload=pbx_dundi.so
noload=app_setcallerid.so
noload=app_dictate.so
noload=res_adsi.so
noload=app_mp3.so
noload=app_privacy.so
noload=app_disa.so
noload=app_alarmreceiver.so
noload=app_externalirv.so
noload=chan_beagle.so
noload=chan_sip.so
[global]
From: App_rpt-users [mailto:app_rpt-users-bounces@lists.allstarlink.org] On Behalf Of Mike
Sent: Tuesday, January 01, 2019 11:10 AM
To: app_rpt-users@lists.allstarlink.org
Mark,
Can you show me the line in your rpt.conf where you are loading the channel.
ie rxchannel = Radio/usb_29285
And your usbradio.conf file text
...mike/kb8jnm
What
On 1/1/2019 9:19 AM, Mark DuMoulin wrote:
Kevin,Brian;
I have been trying to set up use of radiousb instead of simpleusb. I see here Brian is doing that with the issues he is having.
I can't get nearly that far.
I am running hamvoip rc19 on some and recently downloaded stretch.
In both cases I set the usbradio module to load however I cannot get the driver to work and keep getting asterisk failures.
Additionally the menus set up by the programmer show only simpleusb-radio-tune not radio-tune-menu.
Is there another image or procedure I need to run to get this started?
Tnx,
Mark
WB2ERS
Kevin Custer
Sent: Monday, December 24, 2018 2:57 PM
To: Users of Asterisk app_rpt; Brian G
On 12/24/2018 12:21 AM, Brian G wrote:
Ok, I'm thick sometimes :slight_smile: I get what you're saying now, makes sense.
Thank you for the clarification. The Motorola is working as you
described, the other rigs not so much.
So the gist of it is, there's no way to use DSP carrier detect
without using discriminator audio? It's CTCSS or VOX only in that case?
Correct -
BUT, discriminator audio should be available from that M120 radio. You just have to hook it up and possibly program it correctly.
Kevin
This message has been scanned for viruses and
dangerous content by the DTISP MailScanner, and is
believed to be clean.
Leroy,
Thanks for that. I had renamed it and it came up fine.
Now I’m looking at how to do the transmit interface as the encode tone and RX audio are combined from the FOB.
Mark DuMoulin Sr.
WB2ERS
631-484-6960
On Jan 5, 2019, at 15:57, LaRoy McCann <lmccann@dtisp.com> wrote:
Mark,
LaRoy McCann - K5TW
Mike,
Rpt.conf
asterisk.conf local
usbradio.conf.xxx
[general]
[usb1400]
hdwtype=0
rxboost=1
txboost=1
rxctcssrelax=1
rxctcssfreqs=100.0
txctcssfreqs=100.0
;rxctcssoverride=0
carrierfrom=dsp
ctcssfrom=dsp
rxdemod=flat
txprelim=yes
txlimonly=no
txtoctype=notone
txmixa=composite
txmixb=0
invertptt=0
duplex=1
rxondelay=0
rxnoisefiltype=0
eeprom=0
Modules.conf
[modules]
autoload=yes
noload=chan_oss.so
noload=chan_alsa.so
noload=cdr_pgsql.so
noload=app_queue.so
noload=func_odbc.so
noload=chan_mgcp.so
noload=cdr_csv.so
noload=func_moh.so
noload=res_odbc.so
noload=res_smdi.so
noload=chan_tlb.so
noload=app_image.so
noload=app_ices.so
noload=chan_usrp.so
noload=app_amd.so
noload=app_flash.so
noload=app_page.so
noload=app_gps.so
noload=pbx_dundi.so
noload=res_adsi.so
noload=app_mp3.so
noload=app_disa.so
noload=chan_sip.so
[global]
Mark,
...mike/kb8jnm
What
Kevin,Brian;
Tnx,
Mark
WB2ERS
Kevin Custer
Correct -
Kevin
