Asl3 Startup_macro fails at Startup
OS Kernel : 6.12.47+rpt-rpi-v8
Asterisk : 22.5.2+asl3-3.6.3-1.deb12
ASL [app_rpt] : 3.6.3
For the past week or two, I've been experiencing startup problems with the startup_macro. This startup_macro is supposed to automatically connect my node(s) to another node after booting.
This worked perfectly for months, but suddenly it stopped working. If I briefly turn the node off and on again, the startup_macro works, and the desired node is automatically connected.
startup_macro = *3629920
Does anyone know this problem and/or what could be the solution?
’73 Dion PE1ORG
Sounds like possible your network may not be ready at the time the macro runs.
I think you can put a little delay at the beginning with some commas but not sure how many you need.
HamVoIP has “startup_macro_delay” in seconds, which is handy for this sort of thing. Don’t think ASL3 does.
So, what I do instead is put in a bunch of p characters. One p is 500 MS pause.
So my startup macro on a system that might be a little slow to have ready network access might look something like this to make it pause for ten seconds. Kind of ridiculous, but it works.
startup_macro => pppppppppppppppppppp*3506311
Thank you both very much for your responses. I tried both suggestions: a few commas and the letter P, 20 of them. But this morning, after I turned the nodes back on, there was no connection to the other node.
Strangely enough, it did work after I briefly turned the node off and on again. Then the Startup_Macro does work.
startup_macro = pppppppppppppppppppppp *3629920
The nodes connect to my Wi-Fi. For the test, I connected my radio-less node to my wired LAN. But that makes no difference.
I've now increased the delay a bit; we'll see what the result will be.
startup_macro = pppppppppppppppppppppppppppppppppppppppp *3629920
To be continued
Success! I turned the nodes back on this morning and the Startup Macro actually worked again. Hopefully, it stays that way. Of course, the start-up now takes a little longer, but that is not a problem.
Thanks so much for your help and the solution.
’73 Dion PE1ORG
