I have a new install of ASL3 app_rpt version: 3.1.0 DAHDI Version: 3.4.0-4+asl Echo Canceller: Asterisk 20.10.0+asl3-3.1.0-1.deb12 built by builder @ allstarlink.org on a x86_64 running Linux on 2024-11-13 21:20:01 UTC on an HP HPE Edgeline EL10 Computer. I am trying to setup an RTCM for a receive voter for fun and testing. I’ve been unable to get it to work. I’ve been poking around and find that there seems to be a problem with chan_voter loading ,but not running(see screen capture). In CLI I ran the command " module show " which shows all modules loaded and running except chan_voter. I think that this is the problem.
Is there a way of getting this running or is there something else I’m missing?
I am not a good help here, I don’t use this YET.
But the module not loading is a result, not really the core cause.
The bottom error seems the culprit.
Perhaps look at the live results for additional info.
cli> module load chan_voter.so
and see.
Hang in there, not many use these and it may take a day or two to get a knowledgeable reply.
Just popping up to say it’s not because chan_voter is broken in ASL3 or anything like that. I have a multi-site ASL3 VOTER system with full duplex simulcast on the air right now. I didn’t have any issues switching it from ASL2 to 3.
Not super helpful, sorry, but for some reason, the default assumption by most people when they hit an issue using ASL3 seems to be that “ASL3 doesn’t work” or something along those lines, so I just wanted to negate that real quick.
I already load this using module.conf, and tried to reload from the CLI. Thanks Mike.
I’m not saying that ASL3 is broke. Thanks Mason.
I’ve built several nodes and a hub without issues. It just seems that chan_voter is not loading in and running for some reason. If I don’t get a reasonable answer in a day or 2 I’ll rebuild everything again.
Changed port number to 1667 on rtcm and saved then reboot, restarted asterisk service. drop to asterisk CLI, module show same thing not running. module reload same error.
450632*CLI> module load chan_voter.so
Unable to load module chan_voter.so
Command ‘module load chan_voter.so’ failed.
[2024-11-28 20:05:38.965] NOTICE[728]: loader.c:1307 auto_unload_resource: Unloading module ‘chan_voter.so’ that previously declined to load
[2024-11-28 20:05:38.966] ERROR[728]: chan_voter.c:5530 load_module: Unable to bind port for voter audio connection: Permission denied
rebooted computer and checked again and still same issue and outputs.
