I run a VOTER system on a private Asterisk/app_rpt network. I have switched to ASL3 without issues - however, I am unable to get voter.html to function correctly in Allmon3. I am sure I have made a configuration error, but I’m unable to catch my error(s) after reading the Allmon3 documentation.
Debian 12 amd64 VM + ASL3 (fully updated)
; allmon3/allmon3.ini
[1117]
host=127.0.0.1
user=admin
pass=supersecretpassword
voter=y
votertitle=TEST
; asterisk/manager.conf
[general]
enabled = yes
port = 5038
bindaddr = 0.0.0.0 ; Comment when not localhost access
[admin]
secret = supersecretpassword
read = all,system,call,log,verbose,command,agent,user,config
write = all,system,call,log,verbose,command,agent,user,config
;deny = 0.0.0.0/0.0.0.0 ; Uncomment when not localhost
;permit=1.2.3.4/255.255.255.255 ; Uncomment when not localhost
When attempting to access /allmon3/voter.html#1117, I am greeted with an undefined API error:
The logs do not show anything super detailed:
Jul 22 15:58:03 ASL3 systemd[1]: Starting allmon3.service - Allmon3 daemon...
Jul 22 15:58:03 ASL3 systemd[1]: Started allmon3.service - Allmon3 daemon.
Jul 22 15:58:03 ASL3 allmon3[258073]: INFO: (asl_allmon.web_configs) Allmon3 Master HTTP port is 16080
Jul 22 15:58:03 ASL3 allmon3[258073]: INFO: (asl_allmon.web_configs) Allmon3 websockets starting port is 16700
Jul 22 15:58:03 ASL3 allmon3[258073]: INFO: (asl_allmon.web_configs) Binding sevices to all addresses
Jul 22 15:58:03 ASL3 allmon3[258073]: INFO: (allmon3) starting status ws 1117@127.0.0.1 on port 16700
Jul 22 15:58:03 ASL3 allmon3[258073]: INFO: (allmon3) starting cmd ws 1117@127.0.0.1 on port 16701
Jul 22 15:58:03 ASL3 allmon3[258073]: INFO: (allmon3) starting allmon3 master ws on port 16080
Jul 22 15:58:03 ASL3 allmon3[258073]: INFO: (allmon3) starting node_db updater
Jul 22 15:58:03 ASL3 allmon3[258073]: INFO: (asl_allmon.node_db) Retrieving database from https://allmondb.allstarlink.org/
Jul 22 15:58:03 ASL3 allmon3[258073]: INFO: (asl_allmon.allmon3_ws_status) broadcasting status for 1117 on port 16700
Jul 22 15:58:04 ASL3 allmon3[258073]: INFO: (asl_allmon.node_db) Updated node database in 0.78 seconds
Jul 22 15:58:04 ASL3 allmon3[258073]: INFO: (asl_allmon.node_db) populated AllStarlink database
Jul 22 15:58:24 ASL3 allmon3[258073]: ERROR: (asl_allmon.allmon3_server) 1117
It is not clear to me from the Node Configuration section of the documentation what exactly the voters option accomplishes. The description states:
voters- List voters on this server, comma separate. No value disabled voters
but I have yet to see an example of how this is properly used. Do I need to define this?
I can see several public Allmon3 servers with VOTER displays that appear to be working fine, so I’m sure I am missing something simple. Unless… am I the first one to try using a private node # (<2000)?
As always, massive thanks to the ASL team and everyone who supports open-source projects like this one.
