I had sent this before from my mailing list but somehow it was attached as a reply to some previous unrelated subject.
I Guess I ought to ask, Can you start a new subject post from the mailing list? If I am forced to jump through the hoops and log into this group in order to post I saw no place telling me that. On to the original post below.
To ADMIN,
I did a new Debian ASL install on a PC using the link below
With my URIx Sound device plugged in. Booted the PC and logged in as
user repeater
Set chan_simpleusb.so driver to load in the modules.conf
Made sure the rxchannel = SimpleUSB/usb_(node-number) was set correctly
in rpt.conf.
Saved the changes and restarted the PC.
As user repeater entered sudo asl-menu
The asl-menu started.
Selected item #4 ===> Run simpleusb-tune-menu for SimpleUSB configuration.
Does nothing other than to keep telling you…
“SimpleUSB must be enabled in modules.conf and selected in rpt.conf”
Since this was already done. It appears there is something wrong with
the asl-menu item 4.
Returning to the command line and entering — sudo simpleusb-tune-menu
The “simpleusb-tune-menu” runs without issue.
Someone want to take a look at this. I’m sure it would save some new
user a lot of frustration if they try using it while they attempt to get
their new ASL server up and running.
How to Enable Mailing List Mode
<https://community.allstarlink.org/t/how-to-enable-mailing-list-mode/15845>
Site Feedback <https://community.allstarlink.org/c/site-feedback>
By default Community sends email notifications. If you want
Community to operate as a email list server you must enable it.
Here’s how. Just follow the numbered steps below to enable mailing
list mode. Members may post by addressing email to
app_rpt-users@community.allstarlink.org
<mailto:app_rpt-users@community.allstarlink.org> [Screen Shot
2019-12-26 at 9.10.18 AM]
<https://community.allstarlink.org/uploads/default/original/1X/23c932f66eefa194cce9f247805a1b1cf29bc87a.png>
[Screen Shot 2019-12-26 at 9.12.26 AM]
<https://community.allstarlink.org/uploads/default/original/1X/e5ce77607247015c597783edadeb9b1a73e634e4.png>
