We have a large linked network of 900 MHz repeaters. Our main server has 5 HUBs and a handfull of RTCMs defined in the same rpt.conf. This has been stable for a number of years. Today only 2 of the 5 HUBs are registered. I’ve tried shutting asterisk down for 5 minutes and restarting. It’s odd that the same 3 HUB nodes don’t register. The two HUB nodes that DO register are: 41170 and 42610. The three HUB nodes NOT registering are: 27714, 42947 and 49729.
I changed 27714 in iax.conf and restarted. Now it’s registered; but so are the others (inconclusive as to why).
Tom
From: Tim Sawyer via AllStarLink Discussion Groups [mailto:[email protected]] Sent: Monday, February 3, 2020 8:24 PM To:[email protected] Subject: [AllStarLink Discussion Groups] [App_rpt-users] Yet another registration problem
Back in early days of ASL there was only one registration server when ASL was smaller and there was no need to turn on dnsmgr in asterisk.
(Legacy node owner this pertains to your old Allstarlink nodes that have been running for years.)
Recently, because of the growth of ASL over the last few years we have had to add more registration servers to balance the load that was being put on one single server trying to handle more than 3500 nodes all trying to register. Lately, we have been seeing issues with some users registering. I believe these are Legacy nodes owners and are having issues because they do not have dnsmgr enabled for their nodes.
Enabling dnsmgr might help solve your node registration problems.
Basically if you enable dnsmgr, if one of the three registration servers goes down, your node will look for another registration server to register too.
There are three servers, SEA, ORD and CQF, so there is a pretty good chance that your node would be successful registering with another server if one is down or not working correctly.
Thanks Marshall. Yes, I already did that yesterday. Hopefully that will help going forward. That server is an earlier CentOS ACID implementation that’s been running for 5 years; so, I needed to add the /etc/asterisk/dnsmgr.conf file.
