hello everyone,i have a good radio that i want to use as a node ,an Yeasu FT2500.i need an interface and the cable between the radio and the 2500,would you have 2-3 sources please ? i just need a regular interface ,nothing fancy if possible!
my previous interface is burned,thanks if you can help me .73/s.Gervais,ve2ckn
The FT-2500M, according to the manual pages 46-47, requires significant internal mods to provide flat ‘9600’ audio that would be needed for ASL, since the radio does not have a Mini-DIN jack providing a COS output. Personally I would go with a nicer radio (such as an FT-8800 which are easy to find on ebay for <= ~$300, and already have a Mini-DIN-6 jack, and are modern dual-band radios supporting cross-band full-duplex), but if you’re on a budget the 2500M should work fine once modified as described in the manual. Any AllScan URI with a Mini-DIN-6 jack would then work great, see AllScan Products - AllStar Nodes, USB Interfaces, Kits, Modules, MiniPCs, Ham Radio Accessories
