Wrong node number pops up when using Allmon3 Monitoring Dashboard!
ASL [app_rpt] : 3.7.1
I have the following problem:
A system crash has caused that I could not get access to the ASL application any more.
So I have burned a new image for my Raspberry Pi 3b.
I have created two new nodes (690890 and 690891) and I have removed the old nodes (690080 and 690081).
They show up on my account on the allstarlink.org website.
However I cannot access these nodes from my Allmon3 Monitoring Dashboard!
It still shows the old node number (690080) at the top left of the screen (below the home icon) .
In addition, it asks for a user name and password, which I don't know.
HOW can I get access to the new node on that screen, and get rid of the old number?
Pls. adv,
Regards, Tom
PA2TSL
Have a look at ASL Manual : Allmon3 Configuration and ASL Manual : Allmon3 User Management
I have created (again) a new image, and now I can see my node number when I go to my Allmon3 Monitoring Dashboard. In addition, I still CANNOT use the login/password on that page: I do not know WHICH login/password combination is required! Can anyone tell me which login name and password are required??
I will start a new thread because the subject is not very useful any more: I will make a new one (“where can I find the login/password on the Allmon3 Monitoring Dashboard).
Did you look at the link in post immediately before your reply?
there's a short paragraph tucked away inside the ASL3 installation instructions which tells you what to do to set up Allmon3 - look for allmon3-passwd
Thanks for all your suggestions.
I have tried several attempts to find the required information.
For me it is unclear WHICH file I have to get to change/view the login details.
I have opened the file /usr/bin/allmon3-passwd but I don't have any idea where the password information can be found in that file.
In addition I have checked the /etc/allmon3/users file:
user|pass
allmon3|$argon2id$v=19$m=102400,t=2,p=8$qzQqB4hAksPQMj7EB2RrVA$U4tfoQn/CYtY4Hn1j
WGu+g
No idea how to handle this...
Of course, I can make a new image, but I am afraid that I will encounter the same problem with this login problem.
Maybe it is possible to get the correct information form one of you WHICH files I have to view/modify to get the correct login/password information...
Please see the manual: User Management - AllStarLink Manual. It tells you what to do. You don't edit allmon3-passwd (it's a program) nor /etc/allmon3/users (it's a key/value datastore). Run the allmon3-passwd command as shown in the manual, add the user you want to use, and restart allmon3. That's it - as documented.
N8EI: THANKS for this information!
I have created the allmon3 password, and now it is working, finally!
I also was not aware to use "allmon3" for the user.
So now I can proceed with adding my SHARI module.... hope it will cause no problems...
Best regards from The Netherlands,
Tom
PA2TSL
with that done, you might want to run sudo usermod -aG allmon3 <username> to allow you to review the allmon3 configuration files with more without having to use sudo each time
