Working remote base config? - IC-706MKIIG ?
Anyone have a functioning remote base rpt.config file for a
IC-706MKIIG you can email me?
I'm having a heck of a time getting app_rpt to work with my Icom 706
MKIIG as a remote base.
The USB is working ok, but the serial commands aren't making it to the
rig via the serial port.
I know the serial cable is good since I used it to control the rig
with Windows software in the past.
I've checked the CI-V (68) is set in both the .conf as well as in the
rig. Port speed in the 706 is set to 9600.
Am I entering the commands via command line incorrectly?
I've checked the serial ports via dmesg, etc.
Even loaded another PC with a fresh install and no success yet.
Do you have to have two ports? One as a repeater, one as a remote base?
I'm trying to set it up as just one port as a remote base.
The registration is set to "y".
Maybe a real working rpt.conf for a IC-706MKIIG will help. I've
googled several samples but still haven't got it to talk to the rig.
Thanks in advance!
Neil
