How do you add a wifi connection in ASL3 without using the wifi manager?
@node510960local - I assume you’re referring to the WiFi manager web application within Cockpit? That is just a wrapper around NetworkManager. You can use nmcli or nmtui from a terminal/SSH conenction to manage them as well.
