OK, bringing up a new Pi3 with ASL1. This is a HF remote. But I don’t think that is the issue, I have remote=ft100 and iobase=ttyUSB0 as I have used in the past. All seemed ok but all of a sudden if I use simpleusb-radio-tune I can select usb_2428 as interface, it shows up fine but then when doing level set, etc I get this (for #3):
Please enter your selection now: 3
Device usb_2428 currently not active
Enter new Tx A Level setting (0-999, or C/R for none):
core show channels shows no active channels. The RA35 is connected and has a green light so getting power no flashing LED.
I’ve rebooted and power off restart, no change.
Also, since I have not setup a remote for a while and the wiki is very thin on how-to, is all I needed to do was to add the two lines remote=ft100 and iobase=ttyUSB0 ? and the “y” at the end of the node line in rpt.conf?
The old unit crashed and cannot look at the old rpt.conf file.
GeorgeC W2DB
2360, 2428, 28599, 490891
