What does "fever=1" tell me in usbradio_tune_xxxxx.conf after setting up the
receiver?
Bob
kk6ecm
receiver?
Bob
kk6ecm
That mean that it's "infected" with the WORKING version of the front-end code in the xpmr
DSP front-end stuff. (Actually it stands for "front-end version"). There was a bug in older versions
that was fixed, and the "fever" parameter was added to not require older installations to "have" to
re-calibrate their stuff.
Jim
________________________________________
From: app_rpt-users-bounces@ohnosec.org <app_rpt-users-bounces@ohnosec.org> on behalf of kk6ecm <kk6ecm@gmail.com>
Sent: Friday, May 20, 2016 4:53 PM
To: app_rpt-users@ohnosec.org
Subject: [App_rpt-users] What does "fever=1" tell me in usbradio_tune_xxxxx.conf after setting up the receiver?
receiver?
Bob
kk6ecm
Ah, OK, so I interpret that to mean, leave it in, and don't be concerned?
Welcome back Jim... It is good to "see" you reengage.
Bob
kk6ecm
-----Original Message-----
Sent: Friday, May 20, 2016 4:56 PM
To: kk6ecm; app_rpt-users@ohnosec.org
Subject: Re: [App_rpt-users] What does "fever=1" tell me
inusbradio_tune_xxxxx.conf after setting up the receiver?
code in the xpmr
Jim
receiver?
Bob
kk6ecm
Hello list:
I've searched
� and I fully understand the description/explanations given. What I
don’t understand, with specific attention to the lines:
`; name=usb ;
; devnum=1 ;
devstr=4-2 ;
is how to manually uncomment, and manipulate them. In this
particular instance, I’m trying to get a DIAL box running with
one original URI (early version) using the USBRADIO channel
driver, and one URIX (newer version) using the SIMPLEUSB channel
driver. I’ve followed the step-by-step (or was that Crossbar 5
Duude?) instructions for starting off with a single node, then
adding the second node. That simply doesn’t work. The second
URIx green L.E.D. stays solid throughout the process. Are these
lines provided for informational purposes only, or can they be
edited to force the second device to be recognized and assigned?
N5ZUA
run lsusb at the command line, then set
devstr=- for the device(s) shown. Your example is for
Bus 004 Device 002.
Bob
kk6ecm
[mailto:app_rpt-users-bounces@ohnosec.org] On
Behalf Of Steve Agee
Sent: Saturday, May 21, 2016 12:05
PM
usbradio_tune_xxxxx.conf where .conf = .confusion
Hello list:
I’ve searched
http://www.xelatec.com/xipar/node/180
and I fully understand the description/explanations given. What I don’t
; name=usb ;
; devnum=1 ;
devstr=4-2 ;
is how to manually uncomment, and manipulate them. In this particular instance, I'm trying to get a DIAL box running with one original URI (early version) using the USBRADIO channel driver, and one URIX (newer version) using the SIMPLEUSB channel driver. I've followed the step-by-step (or was that Crossbar 5 Duude?) instructions for starting off with a single node, then adding the second node. That simply doesn't work. The second URIx green L.E.D. stays solid throughout the process. Are these lines provided for informational purposes only, or can they be edited to force the second device to be recognized and assigned?
N5ZUA
` Yup, tried that early on with no luck. Then
tried using the (W) command in both radio-tune-menu or
simpleusb-tune-menu. The - listed in the
tuning files does not match what the “lsusb” command reports.
Well, the matches, but NOT the . On a
working ACID install under same conditions, I have two (count
them two) different tuning files where “devnum=3” go figure, and
it works!
N5ZUA
On 5/21/2016 3:55 PM, kk6ecm wrote:
run lsusb at the
Your example is for
Bus 004 Device 002.
Bob
kk6ecm
Steve Agee
PM
[App_rpt-users]
Hello list:
I've searched �[<http://www.xelatec.com/xipar/node/180>](http://www.xelatec.com/xipar/node/180) and I fully understand the description/explanations given.
What I don’t
understand, with specific attention to the lines:` ; name=usb
`; devnum=1 ;` `devstr=4-2 ;` ` is how to manually
them. In this particular instance, I’m trying to get a
second device to be recognized and assigned?``N5ZUA`
_______________________________________________ App_rpt-users mailing list To unsubscribe from this list please visit and scroll down to the bottom of the page. Enter your email address and press the "Unsubscribe or edit options button" You do not need a password to unsubscribe, you can do it via email confirmation. If you have trouble unsubscribing, please send a message to the list detailing the problem.
app_rpt-users-bounces@ohnosec.orgmailto:app_rpt-users-bounces@ohnosec.org** On
Behalf Of**
Sent:
**To:**app_rpt-users@ohnosec.org
**Subject:**App_rpt-users@ohnosec.orghttp://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-usershttp://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users
Ah yes… DIAL is a bit different than
ACID.
For DIAL I get
Bus 001 Device 004: ID 0d8c:013a C-Media
Electronics, Inc.
and
devstr=1-1.4:1.0
but this works also
devstr=1-4
Don’t
know.
Bob
kk6ecm
Sent: Saturday, May 21, 2016 2:05
PM
usbradio_tune_xxxxx.conf where .conf =.confusion
Yup, tried that early on with no luck. Then tried using the (W) command in both radio-tune-menu or simpleusb-tune-menu. The <bus>-<dev> listed in the tuning files does not match what the "lsusb" command reports. Well, the <bus> matches, but NOT the <dev>. On a working ACID install under same conditions, I have two (count them two) different tuning files where "devnum=3" go figure, and it works!
N5ZUA
Bus 004 Device 002.
Bob
kk6ecm
On Behalf Of Steve Agee
PM
Hello list:
I’ve searched
; name=usb ;
; devnum=1 ;
devstr=4-2 ;
N5ZUA
