The set up description:
Our Repeater is using ASL 3 and we had it split on a UHF repeater and a 2-meter remote in the same enclosure.
It had 2 seperate node numbers at first, one for the UHF side and one VHF side.
Since then we removed the main UHF node ID and made it a Hub because of a Port forwarding issue at a different location on a diffenrt IP address and Port.
Ok so the real problem:
During low or no activity times, the repeater wont key up at all like its off.
If you keep keying up on the input, about 20 times it will eventually start working.
If you go on Allmon monitor and re boot it, it starts working.
It is set up so.it re boots everyday at 5 am, but if there has been no activity after the re boot it wont key up.
The last software update was done Feb 11th.
All operations otherwise work fine, it just wont key up after low or no activity.
The VHF link for 2 Meters is linked all the time as well as a 200 Mhz Link always connected to UHF.
I have a person node as well and it never fails or stops working. The 220 Node is not failing either as a stand alone. It seems to benonly the node at the site on the UHF repeater thats failing.
Im at aloss whats goingbon why it just goes deaf and wont key up when its not used for a few hours…
Has anybody encoutered this.
N7COX
STAR IDAHO
